Strange problem removing headers
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Are the collectors bolted to the exhaust, or welded? Some guys do weld them. I wouldn't, but some do.
Exhaust-related bolts are also notorious for rusting up and getting REALLY badly stuck together. Might just need some penetrating oil and muscle to get them out.
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
try heating up the bolts before taking them off or you can spray wd-40 on them and let it sit for a bit.
are you talking about the bolts that go on the heads or the bolts to the y-pipe. it sounds like you are talking about the y-pipe cause you get thoese bolts from underneth the car. as far as the manifold to the head it all depends.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Originally posted by /\/3\/\/l8l3
They are bolted, but I don't see how I can get them off, there just isn't clearance for a wrench, socket or anything to get in their.
Go from under the car, and use extentions... I got my manifold bolts out that way.
red90IROCls1
Aug 25, 2015 06:56 AM
