Can I mount an O2 sensor in a H-pipe?
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I am going to install an A/F gauge and would like to be able to take readings from both banks. If I were to have a small H-pipe put in between the mufflex 3" Y-pipe would the sensor get hot enough to read correctly? I know that some of you will say that there isn't room for a small pipe to connect from one side to another but I've already measured and I can make it work. It will go right behind the header collectors. The H-pipe will also have to be installed off center of the Y-pipe slightly. I may do this regardless of the sensor location.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
The closer the O2 sensor is to the engine itself, the better it will work. IIRC, it has to get up to at least 600* to work properly. I doubt the H-pipe will get that hot.
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
also think about flow.
if you put the o2 sensor into the h-pipe I wouldn't think it would read the exhuast correctly as it would actually inside the header collector
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I've wondered about this myself after after doing Pillsbry's v6 exhaust. The o2 on his car was at the 'Y' on his stock pipe which, seemed like a good idea in that it's reading the exhaut from all 6 cyls or the overall rich/lean of the motor.
On any of mine, it's just getting the o2 from the drivers side. This was a serious problem when I got my camaro as the 5 cyl plug wire was off. This cause the rest of the motor to run ultra lean (judging by the white electodes at leas ton the other 7 cyls).
Would, if poss., a heated o2 solve the temp. problem if mounted further from the collectors ? Do v6 exhaust temps run that much hotter that the o2 can be mounted further away as well ?
