How much gain swapping in LT's w/3.5in. mufflex over Full SLP on 383??
Old May 5, 2005 | 11:05 PM
88GTA3555SPD's Avatar
Car: 88GTA
Engine: 383
Transmission: t5 junk
my friend just installed Hooker 2210's with the mufflex 3 inch y-pipe to a 4 inch catback n spintech muffler. its sounds unbelievable and want to make the swap
right now i have SLP coated 1 3/4 shorties to an SLP 3 inch catback...this is on an 88GTA W/ 383 with trick flow 23* CNC duttwieler heads, 9.9 to 1 compression, comp hyd. roller 528/539 lift 230/234 duration @.050, 1.5 rockers, 30lb SVO's, stealthram, 52mm TB, ram air kit, MSD
how much gain could i expect changing over to the long tubes and the 3.5 or maybe even 4 inch mufflex catback...the 4 inch is way loud and for over 400hp so i dunno
my car was on the dyno and made:
355HP
387ft. lbs torque before the aluminum driveshaft n slp catback
Old May 6, 2005 | 06:18 PM
Car: 88GTA
Engine: 383
you are all a bunch of useless no nothings....26 replies about open headers....heres your answer on that one...bad idea!
thanks for the help! yea right
Old May 7, 2005 | 05:59 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
i'm going from hooker long tubes 1 3/4 to SLP 1 3/4 shortys, 3 inch y pipe and 4 inch cat back. Ill let you know how it turns out. I want to lower my car, thats why i'm doing it.
Old May 7, 2005 | 06:05 PM
sellmanb's Avatar
Car: '86 Berlinetta
you will make a gain going to the longtubes and mufflex catback... whether it would be the best hp/dollar is another thing though. Basically you're looking at spending well over 1000 for a 5 - 10 hp gain.
I wouldnt bother with it, and would just stay w/ the exhaust you have now... or just go with the mufflex catback and stay with your shorty headers.
Old May 7, 2005 | 06:29 PM
Meatwad's Avatar
On Probation
Car: 1987 IROC
Engine: 350?
Transmission: 700-R4
is his fuel injected?
Makes a big difference in sound (carb vs. efi)
Just my 2cents
Old May 7, 2005 | 08:38 PM
Car: 88GTA
Engine: 383
well i could probably sell my entire exhaust system for close to 600%$$$ since its almost new...which would cut down on the expense of the long tubes and the mufflex catback.....the hooker long tubes coated run about 550$ and the catback is like 460$ my friend can make the y-pipe at his exhaust shop....so ill be spending another 500$ roughly...
i was thinking this exhaust woulld open this 383 up a hell of alot more and make at least 25 hp more than what im running now
is it worth it, i dunno??
Old May 8, 2005 | 01:35 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
If you're only making 355rwhp, I don't see you gaining near 25hp from this setup. As mentioned above, I'd expect 7-10 or so. Those SLP 1 3/4" headers flow really nicely, and SLP cat-backs flow very well too.
Not to make it sound like 355rwhp isn't a lot, but you already have a high-flowing exhaust. 25hp gain if you were making like 450-500rwhp would be my guess.
Old May 8, 2005 | 11:22 AM
Car: 88GTA
Engine: 383
yeah maybe you are right about 10hp gains at the most, even though the slp setup is a good flowing exhaust its still a single 3 inch pipe. most could agree it has to be restricting the 383. if you calculate the area in a 4 inch pipe compared to a 3 inch its about double. plus the long tubes will out flow the slp headers as well...thats my reasoning for the 25hp guess
a gain of ten horsepower would suck for the money ill have to spend...so where else could i pull some more power out of this thing....any reason to step up to a 58mm throttlebody??
Old May 8, 2005 | 11:34 AM
LilJayV10's Avatar
Engine: 406 Roller
I didn't have my car dyno'd while it was together. Estimates were 420+ RWHP, it ran 7.8's in the 1/8 on 255/50/16 radial tires. I think if I run the SLP shortys and a good 3inch y pipe into a 4inch catback, that should be a lot of exhaust flow. There are cars running 11's on single exhaust with a lot more power than you have. I'm not saying that to be an ***, I'm just saying that with the power level you have I don't know if it would be worth it. You could have a custom y pipe made into the mufflex catback like you said.
customblackbird
Aug 15, 2021 10:16 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
86White_T/A305
Aug 17, 2015 12:16 AM
sreZ28
Aug 14, 2015 07:48 PM
