Hooker Y pipe and 6qt Moroso pan
Old May 8, 2005 | 01:09 PM
whitez406's Avatar
I just wondering if the hooker 2055 headers and y pipe will work with my 6qt moroso pan or will i have to use the stock pan? Anyone using this setup? Thanks
Old May 9, 2005 | 02:14 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
What does the pan look like? If it is only deeper and not wider, it won't be a problem.
Old May 18, 2005 | 02:15 PM
spacgost79's Avatar
Car: 88 iroc-z
Engine: 5.7 zz4
Transmission: megaraptor 700r4
Axle/Gears: 3.73 10 bolt posi
the y pipe definitly DOES NOT FIT!!! i test fitted slp , edelbrock,
and hooker header kits with the moroso 6qt oil pan for 82-92 camaros, none of the ehausts fit !! had to go back to stock oil pan
Old May 19, 2005 | 01:08 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Not Hooker..but my SLP single cat y pipe fits fine with a Moros #20180 6 Qut pan.
Old May 19, 2005 | 06:18 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
My SLP system fit great with my Moroso 6qt f-body pan.
Old May 20, 2005 | 07:17 PM
carls1982z's Avatar
Car: 1982,Z/28
Engine: 355
Transmission: t350
REPLY
I HAVE A FRESH NEW 355 IN MY 82 Z -AND ADDED THE MORROSO 6 QUART PAN, ALONG WITH A STILL STOCK MANIFOLDS AND CROSSOVER,----NOW CROSS OVER HITS PAN ON EACH SIDE WHERE IT WRAPS AROUND.------I HAVE A NEW SET OF EDELBROCK TUBULAR HEADERS, BUT DONT WANT TOO TEAR ALL DOWN IF THEY WONT CLEAR OR FIT MY 82, CROSSFIRE.--ANYONE DONE THIS COMBO YET,????-----I HAVE EVERTHING NEEDED TO INSTALL BUT HESITANT TOO TEAR APART----EVEN BOUGHT A NEW GUTTED OUT HEAT RISER FOR DRIVERS SIDE, [CROSSFIRE DONT USE]
Old May 22, 2005 | 12:19 AM
spacgost79's Avatar
Car: 88 iroc-z
Engine: 5.7 zz4
i have a zz4 short block with afr heads and moroso pan 20182
6 qt for 86 up blocks. i tried slp , edelbrock , and hooker kits
NONE OF THEM FIT!!! i reinstalled the stock pan and used the hookers,sold the slp, buddy of mine used the edelbrocks on his
engine with a 20182 pan BUT had to severly dent and smash the
y pipe to make it fit!!!!
Hotrodboba400
Dec 10, 2019 07:07 PM
FormulasOnly
Jul 23, 2018 08:47 AM
timonator
Sep 13, 2015 11:49 AM
FtrSpeedy
Sep 7, 2015 12:11 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
