Bending Ceramic Coated Headers
Old May 9, 2005 | 11:51 AM
Got TPI?'s Avatar
Car: 1992 RS / 1986 Iroc
Engine: 350 Vortec / 305 TPI
Transmission: T5 / 700r4 on it's last leg
Have never done anything ceramic coated and honestly don't know much about it. Main concern is there anything I need to worry about concerning the coating? The extent of my knowledge in the area is metal + real hot = malleable Have to bend my lt's b/c of clearance issues with the manual trans.
Old May 9, 2005 | 02:03 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The ceramic can take a little bit of bending. If you have to bend them enough to provide clearance, it probably can't take that much.
As I understand it, you'll only have to spend a little more than what it originally cost to coat the pipes - they'll have to charge you some to strip the coating you ruined, then the same amount as original to recoat them.
All modifications should be performed prior to the coating process. You might want to consider selling your LT's, buying an uncoated set, modifying them to fit, sending them off for coating.
Old May 9, 2005 | 07:16 PM
ckjoshz28's Avatar
Are you talking about hedman, hooker or some other longtubes?
Hotrodboba400
Dec 10, 2019 07:07 PM
sailtexas186548
Feb 17, 2017 03:07 PM
redformula88
Oct 14, 2015 06:08 PM
cstrobel65
Sep 16, 2015 11:54 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
