Ceramic with Wraps
Old May 9, 2005 | 11:26 PM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Engine: 5.7L TPI> 6.2L
Transmission: 700R-4
Ceramic with Wraps
2 questions.....I'm planning on running Hedman 68468 long tubes in the same sort of setup as "Traxion's" custom y-pipe. The system will be a 3" single all the way to the tailpipes. Anyways, these hedders are ceramic coated but don't come with a o2 bung. Hedman has a part # for a 3" reducer (which doesn't reduce as far a I can tell, looks like it stays 3") with a o2 bung, or I can just weld one in after the collector.......
Question #1 If I wrap these headers (which would be a shame cause the thermal coating looks great.) would I still need a heated o2 sensor?
Question #2 Would the ceramic coating keep the exhaust gas temp high enough not to bother with the heated o2 sensor.
Any insight would be greatly appreciated, I'd hate to buy the heated o2 and 3 wire adapter if I didn't need too.
Old May 10, 2005 | 12:25 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
You probably dont need a heated O2 sensor, but it will definitely be better to have one.
As for wrap... don't. You don't need it, because ceramic coating does the same job better, and theres still a possibility of it soaking up some loose oil or fuel and starting a fire.
Old May 10, 2005 | 07:26 AM
safemode's Avatar
Car: camaro rs
Engine: 305 tbi and 350 on stand
Transmission: 4spd auto
Since it's underhood temps you're worried about (as opposed to exhaust gas temp), look into a heat shield for the headers instead of wrapping them. It'll block heat from the engine bay. You gotta be careful with wrapping in order to do it correctly, heat shields are easier.
if you did wanna keep the exhaust gas as hot as possible, wrapping the headers would be pointless without wrapping the entire exhaus system. Most people dont go that far.
sailtexas186548
Feb 17, 2017 03:07 PM
Eric-86sc
Feb 25, 2016 09:02 PM
Rousseau92maro
Feb 1, 2016 05:12 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Accerrito22
Sep 5, 2015 09:34 PM
