Angle plug heads and hooker 2055's???
Old May 14, 2005 | 01:46 PM
Colin91Z's Avatar
Car: 1991 Camaro Z28
The time has come to upgrade my motor, the heads I have are protopline 180cc angle plug heads, is anyone out there running hooker 2055s with these heads or any angle plug heads??? And if they won't fit what headers will? Just curious if I'm gonna run into fitment problem. Thanks
Old May 14, 2005 | 02:56 PM
gta_88_kicks's Avatar
Car: 1988 GTA
Engine: 355
Transmission: 700 r4
I'm using corvette L98 angle plug heads and 2055's they fit fine.
Old May 14, 2005 | 03:04 PM
Colin91Z's Avatar
Cool, thanks. I'm sure mine will fit fine, unless there is a difference between a factory casting and an aftermarket casting. Probably not though. Anyone out there running these headers with aftermarket angle plug heads, can you verify this to set my mind at ease?
Old May 14, 2005 | 06:44 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
There is a difference between the L98 angle plug heads and standard angle plugs heads, so be careful.
Old May 17, 2005 | 03:14 AM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
Im running a set of dart angle plug heads and the 2055's. The only problem i had was the 3rd plug back on the passenger side the one right in front of the dipstick. Its hard to work with not much room. If the dip stick wasnt there i wouldnt have had any problems. Also i dont know what type of spark plug wires your are running but i found that all 90* deg boots work great and are easy to keep away from the headers.
Old May 17, 2005 | 05:39 PM
Colin91Z's Avatar
Cool, Thanks btw, I was running all 90 degree boots with the 2055s on the stock longblock, so i figured i would have to with the new motor too. Thanks again for putting my mind at ease
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
evilstuie
Feb 28, 2016 03:33 PM
CRFred
Feb 7, 2016 11:39 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
