warning 2055 w/ T5
Old May 20, 2005 | 10:37 PM
Souseless's Avatar
Car: 89 WS6
Axle/Gears: 10 bolt T2R w/ 3:23
warning 2055 w/ T5
I finished installing Hooker 2055 headers and I wanted to post a quick warning that I have not seen before. This is only for those with a T5. I thought to look for vacuum lines and spark plug wires toucking the headers before I started the motor but I missed something. The hose that goes from the clutch master cylinder to the slave cylinder was close to the header. After a few minutes of running the hose melted and the headers are jet hot coated. The real bitch of this is that you can not buy the hose. Gm will sell you the master and slave with the hose for 189 dollars, but wtf that is a bit pricy for 18" of hose.
Old May 20, 2005 | 10:40 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If i'm not mistaken, the 4th gen hose is available seperately and will work. It's just a little longer or something like that.
89 formula TPI
Sep 8, 2015 08:00 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
theshackle
Aug 22, 2015 06:52 PM
Bryan F
Aug 18, 2015 02:28 PM
