Should it look like this???
Old May 22, 2005 | 03:53 PM
camaroguy21's Avatar
Car: 1992 Camaro 5.7L Z28
Engine: L98, G92 option
Transmission: Pro-Built 700R4
After 3 weeks I finally recieved one of the Dynomax intermediate pipes that I ordered (part # WLK-43248) and here's what it looks like...
I ordered it from Summit Racing and it's a 3in. mandrel bend. Is there suppose to be a huge crush in the center of the pipe??
Old May 22, 2005 | 04:09 PM
Here's a closer shot of it...
Old May 22, 2005 | 04:32 PM
sellmanb's Avatar
Car: '86 Berlinetta
shouldnt be, and if there is, then I would take it back with reasoning of unsatisfactory product quality.
Old May 22, 2005 | 04:42 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
It's there to clear the panhard bar support.
Old May 22, 2005 | 05:04 PM
I thought of that as well, but I tried to test fit it and there is, at the very least, an extra inch and a half of room to play with.
Does anyone know if this crush will have a negative impact on the inside diameter of the pipe?
Also, if anyone has this same part on their car your help would be much appreciated. Thanks.
Old May 22, 2005 | 05:09 PM
Lo-tec's Avatar
I have an old dynomax 3" mandrel bent kit, and it looks just like yours.
Could you jam 3" in there without the dent? probably
They sell it this way so the average joe can stick it in with no rattles. The inside diameter of the pipe will look just like the outside diameter, and will flow just fine. I'm at 350 to the rear wheels, and doubt it would make any difference if I changed that one small dent. Put it on and enjoy.
Old May 22, 2005 | 08:43 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
I had the same pipe on my IROC and I can assure you it won't affect flow or power.
Old May 22, 2005 | 09:20 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Thats the way they make them and some other manufacturors. I have the 3.50" Mufflex system and it does not have the flat spot. I will be having it installed on my car in June. Allen
Old May 23, 2005 | 06:12 PM
Thanks for all the replies. I guess I'll be installing everything as soon as I have the other intermediate pipe. Good to know that the flow will not be affected. Thanks again, Josh.
