cutting off air tubes...
Old Jun 19, 2005 | 06:11 PM
Crusin' 1980's's Avatar
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
I removed the air pump from my car and I'm thinking about cutting off the air tubes on my 2055s before they are installed...what type of caps can i use to cap the ends off?...i want to have them ceramic coated...will i be ok if i cut off the tubes, crimp the ends and send them to be coated?....what is the best steps to take to do this? thanks
Old Jun 19, 2005 | 06:28 PM
88 Ram Air TA's Avatar
Engine: 305 5.0L F engine code
Cut the tubes off, grind it down, weld the holes shut, grind it down again. And then send them in to be coated.
Old Jun 19, 2005 | 07:02 PM
Car: 1988 SC Camaro
Engine: 305 TBI
weld the holes shut
thanks, but won't the weld drip down into the header?
Old Jun 19, 2005 | 07:28 PM
Nope. Just be careful not to weld to deeply or you will obstruct air flow.
Old Jun 19, 2005 | 11:27 PM
Black Bomber's Avatar
Car: one with wheels
Engine: one with pistons
Transmission: one with gears
Well, that does depend on the welding skills of the person holding the whip.
Brinkkl2000
Aug 4, 2018 08:29 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
Caspar
Jun 19, 2016 11:19 PM
Dialed_In
Aug 20, 2015 01:45 PM
