Do 4th gen Y-pipes fit?
Old Jun 27, 2005 | 08:42 AM
mdricken's Avatar
Car: 92 Camaro
Engine: ZZ4 Crate Engine w/Hot Cam
Transmission: Rebuilt 700R4 with Transgo and MW 3
Axle/Gears: 3.73 Eaton Posi
Does anyone know if a y-pipe from a 4th gen. camaro/firebird would fit on our cars?
The y-pipes in the 4th gen cars look like they would flow much better than the crappy T shaped ones installed in 3rd gens.
Old Jun 27, 2005 | 03:45 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
It might be close, but you will most likely end up having to cut and re-weld somewhere.
Old Jul 4, 2005 | 09:33 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
and then some more.
the flanges on the pipes are different, not to mention the floorpan, and the routing of the pipes.
im not saying it wont fit, you can make anything work.
something custom would flow better and is less of a hassle, IMO.
Old Jul 4, 2005 | 10:08 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Plenty of good flowing aftermarket Y-Pipes for our third gens if I understand your question correctly. The factory 3rd gen Y pipe does cost some horsepower.
Old Jul 5, 2005 | 08:17 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
if you wanna go a cheap route, install a "Y" collector where the 2 pipes come together. thats the most restrictive point. my stock TPI y was 2 3/4 bent pipe. it wasnt too terrible.
Old Jun 28, 2011 | 08:14 PM
RoelSS's Avatar
Car: 86 Trans Am
Axle/Gears: Aussie 9 Bolt with 3.0 Gears
Re: Do 4th gen Y-pipes fit?
I was going to give this shot myself. Did a search and found this. Only reason why I want to use the 4th gen y pipe is because I have one here from my brothers 4th gen.
Old Jun 29, 2011 | 03:18 PM
Pocket's Avatar
Car: 91 Trans Am
Not even close to fitting
sweet_87_iroc
Sep 25, 2015 10:01 PM
hectre13
Sep 8, 2015 03:38 PM
cam-mike
Aug 24, 2015 07:23 AM
