I want headers, can i put them on?
Old Jun 27, 2005 | 12:51 PM
tigercyberslash's Avatar
Car: 1984 Camaro Z28
Engine: V8 350 ci
Axle/Gears: Posi, Disk brakes all the way aroun
i got a 89 camaro 305 TBI and i want that deep sound...i wanan put like REAL duel . instead of just 1 pipe that splits into 2...i wanna know if i can put headers, y pipe and setup like that to get a more muscle sound.
what parts will i need>?
Old Jun 27, 2005 | 12:59 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Real duals receipe:
1 part
2 parts fabrication and sweat.
3 parts reduced ground clearance.
87_350's Avatar
Car: 87 firebird formula
Engine: 350 sbc
Try the search button
Old Jun 27, 2005 | 01:04 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Originally posted by five7kid
Real duals receipe:
1 part
100% true.
Old Jun 27, 2005 | 04:54 PM
blackgloves's Avatar
Car: 1987 IROC-Z
Engine: 6.2L
Transmission: Stage III T56
YES YOU CAN RUN HEADERS
get you a set of Hooker long tubes. Call classic car industries or Year one
year one 800-932-7663
classic car industries 800-854-1280
go to Hookers website
edelbrock makes some, hell just about everybody makes shorties, mids and long tubes for 305's and 350's, your particular year model ect...
Old Jun 28, 2005 | 02:28 PM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
Transmission: 700R4 + Shift Kit
Axle/Gears: Auburn Posi; Richmond 3:73 Gears
Real duals receipe:
1 part
75% True 1 2 yes 3 not always depends on what you want to do. Look at Willie, Greezmonky, Me and others we used stock routing and still have very good ground clearance. If you put the mufflers under the car like many do yes your ground clearance will suffer
Old Jun 28, 2005 | 02:32 PM
Engine: V8 350 ci
someone told me i should get a super cat. with 3in exhaust system to get a mean sound. is this true....what parts do u recomed for a MEAN sound and power...what do u guys got?
i dont undstand this resech i do better if u can tell me some parts:P what parts do u got on a 89 body? 305tbi. i want MEAN and LIL more POWEr is what i am aiming for ...mostly MEAN
Old Jun 28, 2005 | 02:49 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
You can still get a sound with alot of ***** w/o going the dual exhaust route... I don't understand why everyone thinks you cant? That "rough, unsteady-idle" sound has more to do with the cam and heads you have than your exhaust system.
My Z28 has a set of Hedman shorties (68470), modified Hedman Y-pipe, and a Hooker 3" catback. My system is a real 3" system from the Y-collector to the muffler.
Now... Even on a stock-with-bolt-ons 350, my car sounds just as tough and "60s muscle" as my cousin's '63 Galaxie 500, which has dual exhaust and a 390ci big block.
Headers though, will not give you a deep, throaty sound. The muffler(s) and tips will do that for you. You will want two long, large diameter tips to get that sound. Like a pair of 3"x22" tips would work nicely.
Headers will make your exhaust sound uhh.... tinny. They will change the sound for sure though.
Old Jun 28, 2005 | 03:01 PM
Engine: V8 350 ci
"he muffler(s) and tips will do that for you. You will want two long, large diameter tips to get that sound. Like a pair of 3"x22" tips would work nicely."
so your saying all i need is 2 3"x22" tips weilded to my current mufflers and i will have a meaner sound?
and if ui want that throuty sound and uneasy idle like close as i can to a old 60's muscle i need a new cam?
Old Jun 28, 2005 | 05:35 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
It all just comes down to your budget and preferences. Just search through Summit Racing and Jegs and look at what they offer for 3rd gen exhaust parts. One thing to keep in mind is to buy exhaust parts for the TPI engines, everything will bolt up the same (except for the stock catalytic converter) and you'll get more flow than if you bought exhaust parts designed for the 305 TBI.
Here's just one example of a complete exhaust system you can get from a vendor (I'll use Jegs):
Hooker 2055 Super Comp. headers w/y-pipe- http://www.jegs.com/cgi-bin/ncommerc...54&prmenbr=361
Hooker 16823 Aerochamber 3" cat-back exhaust system- http://www.jegs.com/cgi-bin/ncommerc...17&prmenbr=361
Dynomax 15622 Super catalytic converter: http://www.jegs.com/cgi-bin/ncommerc...26&prmenbr=361
Old Jun 28, 2005 | 06:13 PM
Engine: V8 350 ci
i like the 2 following
Hooker 16823 Aerochamber 3" cat-back exhaust system- http://www.jegs.com/cgi-bin/ncommer...217&prmenbr=361
Dynomax 15622 Super catalytic converter: http://www.jegs.com/cgi-bin/ncommer...226&prmenbr=361
so do you think if i got the 2 following , it will add power and flow along with a little more sound as well?
Old Jun 29, 2005 | 09:55 AM
DonP's Avatar
Car: 1990 GTA Black/Black lthr
Engine: 305 TPI stock
tigercyberslash: your links didn't work.
Benm109,
Great advise - thanks. Here comes the old question again - if I have dual cats, should I go to a single? I live in an area with smog checks.
Old Jun 29, 2005 | 10:11 AM
Benm109's Avatar
Engine: 305 TBI
I'm sure someone on the boards can tell you, but I can't. I have never dealt with the stock dual cat set-up nor do I live in a state with emissions testing.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Street Lethal
Apr 30, 2019 12:14 PM
Wvcamaro
Sep 4, 2015 08:38 PM
theurge
Aug 21, 2015 12:46 PM
sreZ28
Aug 14, 2015 07:48 PM
