Header decition on a 383 500HP SBC.
Old Jul 5, 2005 | 01:37 PM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
I know people have asked similar questions, but I just can't find a straight answer to this question...
What headers, (size, company, primaries, collector) do you guys recomend for a 383 stroker that is gonna be putting out around 500 HP, on the street.
And maybe even muffler recomendations. All I know is that I need something in-line because I am dumpin it before the rear. My site has my old/bad idea...
Old Jul 6, 2005 | 05:49 PM
klumb15's Avatar
i would go with the hooker LT's...1 3/4 prims, 3" collector i believe...then run dual 3" or 2.5" back to a pair of mufflers...i would go with something thin...i have mine dumped before the axle, and mine are 4" cases, and hang kinda low...go with like a ultra flo or maybe aerochambers...flowmasters are 5.5", definately don't use them...
Old Jul 6, 2005 | 06:29 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
My car ran the same times open header and with exhaust hooked up.
Hooker super comp LT 1 3/4" primaries 3" collectors
dual 3" exhaust-no H or X pipe
Flowmaster 40 series dumped before rear end
Old Jul 7, 2005 | 01:17 AM
TWICEtheRICE's Avatar
Car: 91' Pontiac Firebird
Engine: 388 ci Small block CHEVY (4.060x3.75), Dart Iron Eagle Platinum 200cc, Performer intake, 454 TBI, Long Tubes, True Dual 3" GPs
Transmission: 700R4, B&M, Governer Recal, 20,000 GVW cooler
I broke out my old high performance engines book, and the chart says...
For a 350 CID engine:
(The RPM is where you want your peak torque to be)
3000 RPM -> 1 1/2"
4000 RPM -> 1 5/8" to 1 3/4"
5000 RPM -> 1 7/8"
6000 RPM -> 2 "
7000 RPM -> 2 1/4" to 2 1/2"
For a 396 its about a size bigger at each RPM.
Old Jul 7, 2005 | 06:36 AM
Engine: LS3
Awsome, thatnks for the help guys. I will def go with the Hooker LT's and dunmp before the rear. Now I have to decided on mufflers. One guy says he is using flowmaster with good results, and another says don't use them at all, due to clearance. i am very interested in clearance.
What is a nice thin muffler, and how close can I put it to the body? Like almost touching or what?
Thanks for any help
Old Jul 7, 2005 | 06:39 AM
IHI's Avatar
IHI
For a cased body muffler flowmaster was the thinnest at the time at 4" thick, and I have mine mounted so it touches the floorboards for max clearance.
You can use Bullet mufflers, but they are VERY loud-ie open header loud.
Spin tech make a 2 or 2.5" thick case muffler but you need ot use oval tubing to hook into it.
Or if your good with a welder you could make your own mufflers.
Old Jul 7, 2005 | 07:40 AM
klumb15's Avatar
flowmaster 40's are like 5 1/2" thick now....the ultraflo is an excellent muffler, and very slim...the aerochamber is thin as well...i have spintech's, and they are pressed right up against the flowboards...i'm lowered 1.75" on stock tires and i scrape only once in a while....
Old Jul 7, 2005 | 08:07 AM
Engine: LS3
Thanks for the insite.
I am leaning towards oval piping, a little more $ but if it saves me from scraping even once I think it will be worth it. Are there any down sides to this idea?
Oval pipes and of course oval mufflers. realy tucked up.
And does anyone know a cheap place to buy oval pipes? Thanks again.
Old Jul 7, 2005 | 01:27 PM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
I'm running dual 3in exhaust that dumps before the rear axle using Edelbrock RPM mufflers. They're only 3 1/2 inches thick. I also ran the same 1/4 mile times through this exhaust as with open headers. Theres some pics of my setup on my webpage, just click the exhaust link on the main page if you want to see it.
Old Jul 8, 2005 | 06:32 AM
Engine: LS3
your setup looks good, ^^^. I am gonna try that with oval tubes. thx
Chad Speier
Sep 24, 2015 12:32 PM
bamaboy0323
Sep 12, 2015 07:14 PM
hdis2002
Sep 8, 2015 02:52 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
