Can the A.I.R tube be replaced with rubbber? (quick response please)
Old Jul 7, 2005 | 08:50 PM
oifish's Avatar
Car: 1992 Camaro Z28
Engine: 5.7 TPI L98
I just need to know if I can replace about 4" of the A.I.R tube that runs to the cat with some rubber tubing. I'd just use pipe clamps to hold the tubing on. Thanks.
Old Jul 7, 2005 | 09:07 PM
Ace's Avatar
Ace
Car: 92 quasar gta
Engine: Nothing
Transmission: Nothing
Axle/Gears: 4.11s
its exhaust gas.. so i dont think ur hose would hold up.. just plug it til you can fix it for good.. its not gonna hurt ur cats that much
Old Jul 7, 2005 | 09:30 PM
oifish's Avatar
Engine: 5.7 TPI L98
Ok, Im going to get some real thick, high temp tubing so it should last. Thanks.
Old Jul 7, 2005 | 09:37 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If the 4" you want to replace is close to the cat, then I wouldn't count on the hose living long. If it's at the engine end it has a much better chance.
Old Jul 7, 2005 | 09:52 PM
oifish's Avatar
Engine: 5.7 TPI L98
Hmm, if I use a propane torch to heat up the coupling between the AIR tube from the engine and the cat, would that make is eaiser to take apart. The problem I am having right now is that I can't get the cat off with out taking off the AIR tube and I can't get that off.
Old Jul 8, 2005 | 06:35 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
Torch is how most people get those connections apart.
Old Jul 8, 2005 | 09:25 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Cut the tube, when you go to put it back together, get a repair kit from the parts store that will have some green high temp rubber hose pieces in it. You only need a few inches worth (and you'll love the price of the repair kit).
I used heater hose on the part going to the headers with no problem. No way I'd use it down at the cat.
Old Feb 25, 2006 | 09:53 PM
thecoolone's Avatar
Car: 89 GTA
are you saying the repair kit won't work for the part down near the cat? If not, then what will?
Old Feb 26, 2006 | 12:30 AM
Jetmeck's Avatar
Car: '89 GTA 9,000 MILES
Axle/Gears: 3.27 9 bolt
He is saying the repair kit with the high temp hose WILL work right at the cat. Any auto parts store will have it.
Old Feb 26, 2006 | 08:00 AM
90CamaroTBI's Avatar
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
What is the repair kit called?
Old Feb 26, 2006 | 10:44 AM
Jetmeck's Avatar
I don't remember if it is called a air tube repair kit or what but don't sweat it just go down to PEP BOYS or whatever and tell them what you need, they will have it.
Old Feb 27, 2006 | 08:38 AM
blackroc68's Avatar
IT IS high temp silicone rubber hose. $7.00 a foot.
gta90
Sep 15, 2015 04:00 PM
mizz0313
Aug 12, 2015 06:45 AM
Fronzizzle
Aug 9, 2015 01:15 PM
Leggman1
Aug 6, 2015 04:15 AM
