Cats
Old Jul 19, 2005 | 12:41 AM
cheese_kake's Avatar
Car: 1992 Camaro Z28
Engine: 5.7 LT1
Transmission: 4L60
Axle/Gears: 3.23's
Cats
I have a 1992 Z28 5.7 , I live in north flordida so we have no emissions tests at all , I was considering taking the cats out , It has the dual cat option , what will this cause , besides the increase in emissions and flow?
Old Jul 19, 2005 | 01:29 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Some increase in noise.
Old Jul 19, 2005 | 02:36 AM
rudyt5000's Avatar
Car: 87-Z r.i.p & 93-Z sold 99s-10
Engine: 305 TPI , 350 LT1, 2.2 4cylinder
Transmission: 700 R4, 4l60, ?
yeah most mufflers sound so much better once you remove the cat converter ....especially IMO flowmasters
Old Jul 19, 2005 | 10:35 AM
Engine: 5.7 LT1
Transmission: 4L60
Axle/Gears: 3.23's
Well what are those two pipes running into each cat , and when I remove the cat will it cause any error codes or will my car run funny or have any negative effects?
Old Jul 19, 2005 | 08:27 PM
rudyt5000's Avatar
those 2 tubes might just be from the smog pump that pump air into the cat so it will heat up quicker and burn more gas fumes and stuff ....and i dont know if it will give you codes but your car will run fine with out them and all that stuff
Old Jul 19, 2005 | 10:54 PM
five7kid's Avatar
The tubes are for the Air Injection Reaction system. They put more air into the cats to aid in the conversion of the exhaust gases. It has nothing to do with warming up the cats quicker.
Removing them will not throw any trouble codes.
Old Jul 19, 2005 | 10:59 PM
Engine: 5.7 LT1
Transmission: 4L60
Axle/Gears: 3.23's
Thanks for the info five7kid , I would have guessed that because there arent any electrical connections going into the cats , but I wanted to make sure. How much louder will it be ?
Old Jul 20, 2005 | 03:52 AM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
about 30% - 40% or so.
Old Jul 20, 2005 | 04:29 AM
DanTheMan_smlk's Avatar
loud enough for people to call you a redn3ck, but not as loud as a 4 cylinder. It will sound terrible when u are goin over 40 and let off the gass...it will rumble and pop
Old Jul 20, 2005 | 05:03 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Thats only some cases (more likely for people who have a manual transmission). I can let off at 5000 rpm and not have one snap, crackle, or pop
Old Jul 20, 2005 | 05:37 AM
haha i can because i only have a cat on
LT1Formula
Oct 8, 2015 08:34 PM
jaridjohn
Oct 5, 2015 07:01 AM
