gasket or not to gasket that is my question
Old Jul 25, 2005 | 12:34 AM
mefang's Avatar
Car: 1985 Z28 IROC
Engine: 5.0 tpi ,mild cam,hypertech flat to
'85 iroc w/stock exhaust Is there supposed to be gaskets anywhere?I Don't remember any when I pulled the motor but the machine shop gave me some that came with the engine gasket set so,I used them and have an exhaust leak
Old Jul 25, 2005 | 12:48 AM
slow84ta's Avatar
Car: 84 15th Anniversary Trans Am
Engine: built 406
Axle/Gears: 3.73 10bolt
Re: gasket or not to gasket that is my question
Umm, there is always a exhaust manifold/header gasket. did u maybe use a header gasket with a stock exhaust manifold or the other way around? that may cuz a leak, bolts not torqued down enough? Use any RTV?
Old Jul 25, 2005 | 01:40 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
There were no gaskets with the stock manifolds. Myself along with many other people here removed our manifolds and found no gaskets.
Do you have headers on there now, or the stock manifolds? I don't think using a gasket with stock manifolds would cause them to leak though.
Old Jul 25, 2005 | 11:26 AM
mefang's Avatar
Car: 1985 Z28 IROC
Yes I used hi temp rtv and torqued 'em properly but it slowly developed a leak.Im gonna put a stethascope to it and find exactly where its leaking and then ditch the gasket(s).Should I use rtv w/out the gasket?are there headers I can run that meet DEQ standards?
Old Jul 25, 2005 | 12:41 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
RTV should not be used on exhaust systems.
Hooker, Hedman, Edelbrock, Mac, and SLP all make emissions-legal headers. They won't fit your stock cat, however.
Old Jul 25, 2005 | 04:11 PM
mefang's Avatar
Car: 1985 Z28 IROC
Alrighty then I'll look into somthing like dual cats or what do you think?
Old Jul 25, 2005 | 06:17 PM
five7kid's Avatar
One option is to get a direct-fit cat for '86-'90 TPI single cat and modify the cat-back to fit it. The cat will slip on to the y-pipe of any of those manufacturer's product for that application.
I haven't checked, but Edelbrock may actually make a set that will bolt to your cat.
Dual cats reduces your choices to Edelbrock and Hedman (not sure about Mac). Also increases the cost since you'll need to buy two cats. And still modify your cat-back (or replace).
Old Jul 25, 2005 | 07:48 PM
mefang's Avatar
Car: 1985 Z28 IROC
thanks for the tip(s)Im going to check it out right now
1992 Trans Am
May 10, 2023 07:19 PM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
redmaroz
Aug 16, 2015 11:40 PM
