unclog exaust
Old Aug 11, 2005 | 01:31 AM
redcamaro1989's Avatar
Car: 1989 rs RIP, 96 grand marquis, 92rs
Engine: LO3, 4.6l, L03
Transmission: 700r4, AODE,700r4
Axle/Gears: 2.73, 3.08, 2.73
unclog exaust
how do i unclog my exaust. it is completly full of black stuff. i have no cat and i went to go get emmisions checked ( i know i would have failed any ways and i found out it had no cat aftwards) and they couldnt take the test becasue of low flow rate and every tie he tried to stick the sensor in the exaust it would come out with black stuff all over it and some would fall out of the exaust
Old Aug 11, 2005 | 01:42 AM
i know i need a new exuast....but im completly broke
i have like 30 dollars
Old Aug 11, 2005 | 06:17 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Is your car running rich or is your exhaust really clogged? Every exhaust system will have a layer of carbon on the inside. Are you sure your system just isn't rotted and peeling away? $30 won't get you much. Your best bet would be to find a used exhaust off of another 3rd gen. You really should find out why your car didn't pass. Find out why it is not running the way it should be. Chances are the exhaust is not your first problem that you need to be solving.
Old Aug 11, 2005 | 06:38 PM
i was standing there when they took it. the computer said low flow rate and the sensor could read it and the guy said my exuast is clogged pretty good. i saw for my self all the black over the sensor and falling out
Old Aug 12, 2005 | 05:49 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
You may have a clogged cat but exhaust pipes just don't clog. I would look into replacing the cat.
Old Aug 12, 2005 | 11:50 PM
it dont have a cat. it is cut off
Old Aug 20, 2005 | 12:16 AM
tony1784's Avatar
Car: 85 Trans Am
Engine: SBC
Transmission: TH400
Axle/Gears: Moser/Strange 9"
I'm just replying because I'd like to keep tabs on where this goes.
theurge
Aug 21, 2015 12:46 PM
grouper
Jun 11, 2001 08:42 PM
Kingtal0n
May 4, 2001 04:12 PM
Burton69
Mar 28, 2001 12:12 PM
Jester
Oct 11, 2000 08:29 AM
