power limits of exhaust sizes?
Old Aug 15, 2005 | 03:04 PM
b00stn's Avatar
I'm just looking for some educated guesses on what power levels different size setups can support (this is a turbo application, not sure that it matters with regard to flowrate) without becoming TOO much of a restriction. This would be at the most restrictive part.
My inital guesses -
Single:
3" - 500hp
3.5" - 750hp
4" - 1000hp
Duals:
2.5" - 700hp
3" - 900hp
3.5" - 1200hp ?
I'm basing this on cross sectional area, taking into account that two pipes at the same area will have more friction due to surface drag, and also what i've seen other cars make with a certain exhaust setup. I'm sure its more complicated than i'm making it. Just throw some numbers out there.
Old Aug 15, 2005 | 08:05 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Here is a pipe diameter chart from Dynomax/Walker. Magnaflow and Flowmaster have similiar charts. I have posted this a couple of times but it needs to be shown again from time to time.
Attached Thumbnails power limits of exhaust sizes?-dynomax-pipe-diameter.jpg
Old Aug 15, 2005 | 08:11 PM
crazy3rdgen's Avatar
Car: 2002 SS
Engine: Ls1
Axle/Gears: 3:42 posi
so 400 hp on a 350 = ? lol
Old Aug 15, 2005 | 08:48 PM
Car: 1989 GTA
Engine: 369 TPI
I hope to be at the 400HP mark on my 350 in a couple of months. Hehehehehe. Just a couple of more mods and with TPI no less. Also looking to be in the 12.5's come this Fall/Winter and the cooler weather.
Old Aug 15, 2005 | 08:50 PM
Car: 2002 SS
Engine: Ls1
Wups i messed up my bad,
i meant to say
450 hp on a 350 would = what size pipe. Probably going with a single . 3.5?
Old Aug 15, 2005 | 09:31 PM
Car: 1989 GTA
Engine: 369 TPI
At 450HP the chart says either a 3" dual pipe or you should consider a 4" single pipe for optimum performance.
Old Aug 15, 2005 | 11:08 PM
slickrock55's Avatar
Car: 82 Trans am
Engine: Twin turbo 350
i hope thats a pretty conservative chart. I'm planning on single 4" split off to dual 3" and straight through mufflers. I need that to be good to 600-650ish. hmmm . . . .
Old Aug 16, 2005 | 10:40 AM
Car: 2002 SS
Engine: Ls1
but mines a 5.7 wheres is say in there
350 5.7l 450 hp lol
Old Aug 16, 2005 | 01:05 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
a 450 hp 350 I would probably run 2.5" - 2.75" duals on. 3" duals are way overkill, 2.75s are a little big.
For a great discussion on this, click the link:
http://www.fbody.com/cgi-bin/anythin...i?msgid=766773
VERY informative - even includes neat drawings!
Old Aug 16, 2005 | 04:10 PM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
fyi, i run 450horse on a 1 3/4 lt headers to 3" dual to a y, which is 3" back...
Old Aug 16, 2005 | 06:06 PM
Car: 1989 GTA
Engine: 369 TPI
The above chart is just a guide line.
Vintageracer
Jan 10, 2020 05:33 PM
toronto formula
Nov 10, 2015 06:17 AM
69 Six Pack
Oct 5, 2015 07:51 PM
bamaboy0323
Sep 3, 2015 06:07 AM
knight72
Aug 10, 2015 09:32 PM
