Exhaust Adapters !!!Confused
Car: 86 Z28
Engine: TPI 305
Im having a little issue with exhaust adapters ,confused on how they work with ID and OD figures.
I just purchased a flowmaster 80 series muffler for my 86 camaro Z28 with engine code(F)305 V8 TPI the one the the permance shop in my area gave me was one with (1) 3 inch inlet and (2) 2.5 outlets crossflow design my problem is my main pipe is 2.5 inches not 3 inches.
this muffler cant be return without paying a restock fee
can someone help me with what size adapter i would need to put this on my 2.5 main pipe
the ID and OD thing really screws me up,ican order one from summitracing but i dont want to order the wrong one.
would i need one thats for example 3"inche ID to 2.5 ID
confused!!!
Thanks for Any Help!!!
Repzard
confused!!!
Repzard
Car: 81 Corvette
Engine: 355, ported vortec heads
Autozone will stock all sorts of adapters.Get a 2.5 to 3 adapter. Rent a tail pipe expander to help aid with the proper fit.
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Yeah, check the Zoners or Pepboys. Also, check the muffler itself. WHen I did mine many moons ago, my 80 series inlet was a little long. Appon further inspection I found that it was a built in adapter that Flowmaster was doing for a while there. If your system was 2.5 it would go right on. If your was 3 you just had to cut off the excess and it would go right on. If not, the above mentioned should do it for ya. Good luck.
bubbaz28
Sep 18, 2015 02:09 PM
