Muffler Question
Old Sep 14, 2005 | 12:31 PM
TJfive0's Avatar
Car: 2008 Toyota Rav 4
Engine: V6
Muffler Question
If you have a muffler on your car, doesnt matter if it is upside down? The inlets and out lets would be kept the same, the only difference is the muffler would be upside down. Would this effect anything or potentially harm anything? Also would this still pass emissions?
I heard that it might cause a potential problem with the condensation forming and what not.
Thanks,
Tony
Old Sep 14, 2005 | 01:14 PM
superGMman's Avatar
Car: '92 Toyota Pickup
Engine: 22R-E
Transmission: 5sp Manual
Axle/Gears: 4:??
All I know is that the number one killer of mufflers is condensation in the muffler. You can prevent rust. What happens is if the exhaust doesn’t become hot enough so short trips leave water in the muffler. I know because in my car my muffler is mounted sideways and I have to replace the muffler every year so, so through my experience I’d say try not to put it in any weird position. Hope that helps.
Old Sep 14, 2005 | 05:08 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
replacing the muffler every year or so?
ive never seen a muffler "rust out" in a year....
aftermarket mufflers shouldnt matter which way you mount them.
factory mufflers have a lil drain hole, so some might mount in a certain fashion.
Old Sep 14, 2005 | 05:21 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
shouldnt matter.
Old Sep 14, 2005 | 05:26 PM
superGMman's Avatar
Engine: 22R-E
Axle/Gears: 4:??
The mufflers I use are far from aftermarket, just some info as to what I've experienced.
Old Sep 14, 2005 | 05:42 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
must be crappy to rust in a year, IMO.
Old Sep 14, 2005 | 06:49 PM
superGMman's Avatar
Engine: 22R-E
Axle/Gears: 4:??
You have no idea. Probably last longer than flowmasters though
Old Sep 14, 2005 | 07:11 PM
TJfive0's Avatar
Engine: V6
By the sounds of it, It shouldn't effect too much. And it seems it should still pass emissions. I just can't afford a new cat back system yet.
I guess I will try it out. Now I have to rotate the tail pipes about 180 degrees. That is going to be a pain.
Well I guess we will see.
Frozer!!!
Jan 19, 2024 04:55 PM
formula_novice
Sep 5, 2015 03:58 AM
Thirdgen89GTA
Aug 20, 2015 12:11 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
