My idea on a good LT set up...have not seen anything similar yet
Old Oct 4, 2005 | 12:24 PM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
Ok here is my idea for a nice light weight simple powerful exhaust.
Hooker 2210s then a mufflex Y-pipe into a 4"spintch muffler and a turndown. Thats it. Nice and simple.
What do u guys think?
Old Oct 4, 2005 | 03:16 PM
2slow5.0's Avatar
Car: 91 Formula
Engine: 5.0 tpi slow
Transmission: WC t-5
Probly gonna be loud, real loud.
Old Oct 4, 2005 | 04:23 PM
84firebird383's Avatar
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
You would also have little to no ground clearance.The mufflex Y-pipe uses s bends to get underneath the tranny crossmember and the muffler would end up directly under the torque arm and drive shaft.It would work better with a bullet style muffler,but it would not be much if any quieter than open exhaust.(I know I have done this to my car for a brief time)
Old Oct 4, 2005 | 06:58 PM
Engine: LS3
Sooooooo..........any suggestions on how to get more ground clearance?
I am thinking about just running oval pipe maybe and do duals, that dump. I can weld myself so let me know what you guys think.
One last thing. I allways thought the mufflex y pipe was a great thing to use if you want ground clearance. Was a totally wrong?
I allready have the coated 2210s. THanks guys
Old Oct 4, 2005 | 07:35 PM
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
I don't have any ground clearance issues with my mufflex y-pipe,but I run a complete exhaust with muffler in stock location.My car is also stock ride height so I have about 4" of clearance between the part of the Y-pipe that goes under the crossmember and the ground.If you wanted to run a muffler other than a bullet style muffler right off the Y you would have to off set it, and if you are going to do that you might as well run duals.The mufflex y-pipe comes in pieces that you could use to start a dual set up,but at $250 its a pretty expensive way to start.The best way I saw for clearance with out cutting up the floorboards would be to get 2 mufflex y pipes(or have a shop duplicate some of the bends from the first y-pipe),take the pieces from the Y- pipe to S under the crossmember then take the duplicated pieces and S back up into the driveshaft tunnel and run some straight pipe to a pair of bullet style mufflers and dump them infront of the axel. You could probobly also put an H pipe in it if you wanted.
Old Oct 5, 2005 | 09:09 AM
Engine: LS3
Hmmm, sounds like an idea that might work. I can fabricate stuff and I have no problem beating up the floor boards. I have done it before when I thought i was going to run a cut out. Now I learned there is no reason for a cut out on a crazy set up like this.
All I really want is a well flowing exhaust that gets nice clearance. I don't need the most efficient system ever made. Do you guys really think i should go up over the axle? Does that GAIN me clearance? I would think that I can stuff a muffler someplace before there and keep the car quiet.
I am just worried because my cam is pretty crazy and I want to keep the car quiet.
I want to keep the price off all the stuff I have left to buy under 600 bucks. I have 2210s, and tips if i need them. I think the rest should be able to stay in my price range.
My car is lowered allready, Does the mufflex pipe interfere with spohn TQ arms? That is what I have.
OR should I just buy a bunch of 3" or 3.5" tubing and bends and take the time to fab the whole damn thing from scratch routing the pipes in whatever nook and cranny i can to gain clearance?
I want to order all the stuff this afternoon.
Any thoughts, please chime in. Thanks again.
Old Oct 5, 2005 | 03:31 PM
Aweasel's Avatar
Car: Red '89 IROC-Z
Engine: 350, Patriot 195s,
Transmission: T56, Hurst Shifter, Alum. DS, 3.73
From what I've heard, Hooker LTs and lowered cars do not go together very well at all. just a heads up but I think that sounds like a good setup.
Old Oct 6, 2005 | 06:38 AM
Engine: LS3
yeah I am aware. 2210 and lowering = not good. But oh well, I kinda want to try anyways. I have exelent roads where i live, so i am confident i can get it to work. All oval pipes should help
specialized
Jun 18, 2022 09:26 AM
Fast355
Dec 2, 2016 06:33 PM
Wvcamaro
Sep 4, 2015 08:38 PM
Navy8125
Aug 22, 2015 07:13 PM
mx127
Aug 10, 2015 08:13 AM
