DOes anyone make single 3.5 or 4.0 inch exhaust!
Old Oct 19, 2005 | 09:45 PM
welterracer's Avatar
Car: 1991 Camaro RS convertible
Engine: 305 Tb
Transmission: 5 spd soon to be T56 6 speed
Axle/Gears: 3.08 soon to be 4.56
I currently run 12.20 at 120 threw the stock 2 3/4 exhuast with headers and a 3 inch muffler and tailpipe!
But i gain half a second using my exhuast dump..
Is there anyone other there that makes a good 3.5 exhaust or 4.0 exhaust that isnt too loud..
THanks
Brian
Old Oct 19, 2005 | 10:18 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
You have obviously done alot of work and spent some good money to go that fast... why not spend another $50 and get a pair or 3" cutouts and use one on each collector? Thats the most free-flowing exhaust you could have, which would be to your benefit, considering it takes around 500 fwhp to go that fast.
Old Oct 19, 2005 | 10:26 PM
superGMman's Avatar
Car: '92 Toyota Pickup
Engine: 22R-E
Transmission: 5sp Manual
Axle/Gears: 4:??
I agree with the previous post but mufflex is the home of the 3.5" and 4.0" catbacks.
Old Oct 19, 2005 | 10:27 PM
Engine: 305 Tb
I want it to run that fast threw the exhaust and not have to jack around taking off the exhaust caps..
New Z06 vetts are supposed to run as fast as my car... and they have full exhuast..
Old Oct 19, 2005 | 10:28 PM
Engine: 305 Tb
Do you have a link or a website to visit?
Old Oct 19, 2005 | 10:30 PM
superGMman's Avatar
Engine: 22R-E
Axle/Gears: 4:??
http://www.mufflex-performance.com/
There ya go!
Matt.
Old Oct 19, 2005 | 11:00 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
After 3500 RPM the Z06 opens up another set of pipes and its straight out. I saw this on CNN's business section today.
Old Oct 19, 2005 | 11:03 PM
Engine: 305 Tb
Actually the Z06 has butter flys in the exhaust tips like a Throttle body/carb and is almost completly closed at idle and slowly opens with the exhuast.. that is why they are soo quiet at idle but soo loud at WOT
but the exhaust is still going threw cats and alot of pipe..
Old Oct 20, 2005 | 10:58 AM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Yup, contact mufflex and go from there. Word of advice though, unless they've changed the hanger setup, don't use there crap. Get some REAL exhaust hangers and weld it up yourself. The way they send it to you will work but it hangs a little low. With a few cuts and some better hangers, you can tuck it up nice and tight without even being seen.
Good luck
Old Oct 20, 2005 | 05:35 PM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
Use your 2 3/4 pipe as a pattern. If you can weld and cut, order yourself some straight 3 1/2 or 4" tubing and mandrel bends and cut an tack yourself a pipe together that mimmicks the pipe you have. You will have to get creative at the connections though.
Old Oct 20, 2005 | 05:53 PM
Engine: 305 Tb
IS it extremely loud? Mine right now is pretty quiet .. Im using a dynomax 3 inch muffler!
Old Oct 20, 2005 | 07:56 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Magnaflow just came out with a 3 1/2 inch muffler that will work with our cars and the Mufflex exhaust. In fact you can order it with the kit from Mufflex. The part number is 12909. It is of the straight through design and is long enough to be on the quiet side. I have one on order through Summit and it is supposed to ship on 10/30/05. Hope this helps.
Old Oct 20, 2005 | 09:47 PM
batchik2's Avatar
Car: '86 Z28 Chassi, '91 V8 S10
Engine: 350 bored .030 new cam, #416 heads with 1.94" intakes
Transmission: S10-NV3500 5spd
what is the main purpose of this car? why not just run lt's and 2.5"- 3" duals. you will have a much better performance gain. and im sure you could find mufflers like super turbos or something that are decently quiet.
Old Oct 20, 2005 | 09:54 PM
Engine: 305 Tb
The main purpose is to be a super fast street car! with stock like amenitys!
I had made duals along time ago... too much added weight and poor performance..
a good single 3 inch exhuast is hard to beat.. Many dyno tests have proved how great a single exhuast can be..
Hell i ran 12.20 at 120 threw the stock extension pipe and 3 inch muffler.. and that was spinning in second gear..
Old Oct 21, 2005 | 10:20 AM
jimp2001's Avatar
Car: Red on Red 89 RS
Engine: LO3 305 TBI
Transmission: TH-700R4
Axle/Gears: 10-bolt / 2.73
Anyone have the link to pics of willie's dual 2.5" setup?
I think you definately need to run true duals with that hp... or at least a 4" mufflex
Old Oct 21, 2005 | 10:53 AM
batchik2's Avatar
i just saw a recent post last night about shortys and duals. i think the pic was a black Z28.
for that much power man your gonna need duals. 2.5 inch set up into a set of those dynomax race mufflers or something of the equivalent. a single Y-pipe set up is like breathing through a straw.
Vintageracer
Jan 10, 2020 05:33 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
TheExaminer
Aug 26, 2015 04:59 PM
gta power
Aug 13, 2015 06:15 AM
Exxon Limited
Aug 9, 2015 08:13 PM
