Thinking about cutting my tips off
Car: '06 Nissan Sentra SE-R Spec V
Engine: Big block 2.5L
Transmission: 6 Speed
They're too big, stick too far out, and aren't even. I was thinking that if I cut them off so it would stop before it reaches the bottom of my bumper so you can't see the pipes, but what about the exhaust fumes? Would they come up through the back of the car??
Car: 91 camaro 305 tbi
Engine: 305 tbi l03
you may be able to buy some pipe thats turned at a 30 degree angle or something and make your own turn downs to direct it more tword the ground if your concerned about heat or smell.
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I cut mine off (I hate round pipes sticking out of a rectangular bumper) and no smells or noise or burning. Just ended about 5" before the end of the car (back of the bumper cover).
Car: 93 z28,89 formula350 92 formula350, 92trans am 350 6-speed,1992 3.1 firechicken,1991 z-28 350..1986 hearse
Engine: several350tpi,lt1,3.1(haha)
Transmission: auto...6-speed
sawzall 2 minutes...don't worry about fumes unless its a rotbox
Car: 86 T/A
Engine: HSR 355
You're a monster if you can hacksaw that off it 5 minutes. I used a crappy jigsaw and it took like 5 minutes a piece. Sawzall was roughly 14 seconds per pipe (after I smartened up).
Car: 90 firebird
Engine: 350 5.7L
Transmission: Th-400 w/ Manual valve body
Axle/Gears: 4.10 Richmond gears
in ct it's illegal to let exhaust end before the rear axle if it;s a 4 pass car. that's kinda the minimum in my book
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
actually it is illegal to to just dump off under the car here in ct, but you can dump out in front of the rear wheels. As long as you are outside of the body. That is the way I had interpereted the laws.
Car: 1989 RS Camaro
Even If it goes out the side of the car? like the way the old vettes used to run there's? Damn. there goes my dual exhaust plans.
Car: 90 firebird
Engine: 350 5.7L
the jegs universal exhaust drops before the axle to the sides. too bad, it's real cheap and i need a full exhaust.
