HVAC box heat damaged from headers!
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
I have noticed on two 1990 IROC-Z cars I own, that the heater/A/C box has been damaged from header heat. The first one was actually melted to the point that you could see the evaporator core. The second one melted the foam insulation inside the box.
The damage was done prior to me owning the cars.
I bought a 12"X12" piece of heat barrier ( Cool It Thermo Tec Summit #THE-13500) which is adhesive backed, and I had planned to install it onto the outside of the box between it and the headers. Upon receiving it, the instructions state that it can be good up to 2000 degrees. But the adhesive backing is only good for 300 degrees! Not wanting to take a chance with this stuff, I am also planning on using some of the Thermo Tec Clamp-On Heat Shields (Summit part# THE-11630). I want to keep my A/C.
Does anyone have any experience with this product, or this problem?
Car: '82 Z28
Mine crumbled taking it out to put a regular heater setup in. Use that thermal deal on the box, it'll stand up to the heat just fine.
Car: 1982 Z-28
I don't think it/they were running lean. I see you are from Pensacola, that is where the car came from! You may have seen it running around down there a couple of years ago, a white 1990 IROC-Z with two black stripes front to back over the hood and hatch.
Car: 1999 Saturn SL2
Engine: 4 cylinder
Transmission: 4-speed automatic
There are a lot of thirdgen Camaros running around this town, so forgive if I say I can't recall that one car in particular. Sounds like a cool car, though.
I only asked about running lean because I know that headers can get EXTREMELY hot in a lean condition (1,300 degrees F and higher). That would definately be enough to melt plastic, even if it wasn't relatively "that close" to the box.
1992 Trans Am
May 10, 2023 07:19 PM
Dyno Don
17
Nov 2, 2015 11:43 PM
777Shock777
Oct 29, 2015 04:30 PM
Dialed_In
Aug 20, 2015 01:45 PM
