Dynomax cat question
Old Nov 10, 2005 | 03:13 PM
redliterunner's Avatar
Car: 89 IROC convert.
Engine: tpi 305
Axle/Gears: 3.42 10 bolt
Jegs has a direct fit Dynomax super converter for my camaro for just over $100.
If my stock 1989 converter is a honeycomb type, will I see any improvement with the Dynomax job?
Is there a better direct fit converter than the Dynomax?
I'm putting headers on and want to get the most out of them.
Thanks.
Old Nov 10, 2005 | 03:23 PM
Nate86's Avatar
Car: 1999 Saturn SL2
Engine: 4 cylinder
Transmission: 4-speed automatic
If it's a direct replacement for the factory cat, you might need a reducer to mate it to the y-pipe/catback, depending on which headers/catback you get.
I think the best idea would be to find a 3" high flow cat mated to a good 3" y-pipe and a 3" catback. All the factory restrictions are eliminated in that setup.
chazman
Aug 28, 2018 03:25 PM
billybob6110
Sep 24, 2016 09:50 AM
chazman
Aug 22, 2015 02:01 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
