Converters are a joke
Old Dec 2, 2005 | 05:13 PM
90CamaroTBI's Avatar
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
Ok well I want a 3" Dynomax catback that I can just bolt in with no welding involved. I have searched for the 3" catback in summit and jegs and just cant find it (If anybody knows the part number or where to get it please let me know). But I have been thinking and realized that since its a TBI and wont haved much done for a while, I can settle for the 2.5" catback. Ok what is required converter-wise to put it on? Will my stock one bolt to the catback? Also if I have to get a new cat, where can I get one with a 2.25" inlet and 2.5" outlet...all the ones I have seen seem to be the same in and out. Any help from you guys would make me really thankful. Thanks guys.
Old Dec 2, 2005 | 05:18 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
You can buy small adapter rings that will work for just that... if you want to slip a 2.5" pipe over a 2.25" pipe, you slide this ring over the smaller pipe, and put the bigger pipe over it. Its basically a spacer. You use an exhaust clamp to hold it together. Worked nice on my cousins exhaust when we had 2.25" pipes and wanted to use 2.5" cutouts.
Old Dec 2, 2005 | 05:30 PM
Engine: LB9, LB9
Thanks man, have any idea where I can get me some of them?
Old Dec 2, 2005 | 06:10 PM
Air_Adam's Avatar
I've seen them at all the basic parts stores... Canadian Tire, Autozone, places like that.
Look in the exhaust section, where the sell the chunks of pipe, clamps, etc... it will be about 1.5" wide, have a split at one part (so it can be squeezed by the clamp) and quite thick... you'll know it when you see it.
loud91rs
Camaros Wanted
Mar 28, 2016 04:13 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
okfoz
Oct 13, 2015 02:19 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
