Would these manifolds be any better than stock?
Car: 87 Black Formula
Engine: Rollercammed Lg4
Axle/Gears: 3.23 10 Bolt Locker
I found these manifolds on my local ebay equillant, it say's they are for "older smallblocks", don't know what year. They are $70.
I don't need egr and the air stuff, don't have them on now, and it's stock.
But would it give any power boost? or would L98 manifolds be better? I have the LG4 "log style" ones now.
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Those don't look much better. You can get used hedman shorties for that price, but you'd still need y-pipe so it'd cost more.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Originally posted by ShiftyCapone
Use the L98 manifolds and do not spend $70 on those. Those appear to be truck manifolds.
Trucks, F-bodies, A-bodies.... everything
Car: 1989 C4
Axle/Gears: 307
Would they? Yes! They do fit too in case you were wondering but it would take a real trick muffler shop to fab up a y pipe. BTW they flow alot better then any stock 3rdgen exh manifold.
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
Those look really cool!
If you do get them, be sure to get a carbide bit and then gasket match the ports to your heads in order to get the most flow possible.
I'd get them bead blasted and paint them with high temp paint first. The paint will probably burn off, but they'd look really good at first.
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
pass side one wont fit a third gen F body
been there done that with these in my 82 before
reason why not:
top stud hits firewall before you can even mount the manifold to the head
those manifolds were on cars trucks vans from about 69(cars) 73(trucks) through 86(cars quit using them in 79)
the most common design manifolds gm ever made
some are braced and some are not
non braced ones are junk due to being warp/crack prone
the ones in the pic are non braced, they are nice boat anchors
stock restrictive junk, but do sound good with dual pipes, but no good for any performance gains
good luck
reason why not:
good luck
ambainb
Apr 25, 2016 09:21 PM
transaero
Aug 31, 2015 01:14 AM
Dialed_In
Aug 20, 2015 01:45 PM
