what size muffler?
Old Dec 15, 2005 | 12:10 PM
blackgloves's Avatar
Car: 1987 IROC-Z
Engine: 6.2L
Transmission: Stage III T56
what size muffler?
Heres the thing. Im about to buy mufflers for a true dual system for my 84 Z28 I need to know who is running a system, and what size mufflers you have? What brand you have as well? If I get that info, the company im going through will cross over the info to their products.
blackgloves
Old Dec 16, 2005 | 09:49 AM
Car: 1987 IROC-Z
Engine: 6.2L
nothing?
Not one good answer?
Old Dec 31, 2005 | 12:08 AM
tigercyberslash's Avatar
Car: 1984 Camaro Z28
Engine: V8 350 ci
Axle/Gears: Posi, Disk brakes all the way aroun
i got a flo-master super flo cat with a v-force muff. along with 2/34 in pipes, sounds very nice and nice power! cost me around 500.00 for everything
Old Jan 2, 2006 | 07:43 AM
brutalform's Avatar
I would personally stay away from Flowmaster. You need a muffler that flows in relation to the power your making. If you are choosing a muffler on sound alone, then the sky is the limit. If not, then check out this article.
http://superchevy.com/technical/engi...t/0505phr_exh/
Old Jan 2, 2006 | 12:24 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
How much power is your car making? You might want to consider a single 3" or a dual 2.5" setup depending on your motor. Muffler choice is largely a personal one, however I'd recommend staying away from flowmaster.
Old Jan 3, 2006 | 12:15 AM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Dynomax super turbos are an excellent muffler that iIve use on several different vehicles.Excellent flow,actually outflows "40"series Flowmasters below 3500rpm,without the noise.Very nice rumble at idle just a touch above stock not ubtrusive at hwy speeds(55 to 70).Or you can go to their Ultra Flows which are stainless and quieter with same flow.Single 2.5" mandrel bent is good on a stock motor or 3" on modified.If you go duals,wouldn't go bigger than 2.5", use a balance tube for it's scavenging boost low end torgue.
PurelyPMD
May 5, 2016 04:57 PM
Nervous2
Oct 8, 2015 10:53 PM
cstrobel65
Sep 16, 2015 11:54 AM
m00n420
Sep 11, 2015 02:39 PM
Stroopwafel
Sep 11, 2015 06:38 AM
