True Dual 3 inch on a 383...
Car: 1986 Camaro
Engine: zz4 350 w/mods
Transmission: 700-R4 W/Shift kit
I finally got the new motor running.
I had a 383 built
508 hp
560lb ft at the motor, on the motor dyno
Fully forged bottom end
11 to 1 compression
ported dart pro 1 200cc heads
2.02 intake 1.6 exhaust valves
custom hyd roller cam
edelbrock rpm air gap intake
nos super powershot (has yet to been used, still breaking motor in)
holly 750 dub pump, tuned on dyno
i have gone through 2 700R4 tranny builds in a month and a half, and i am switching to a turbo 400 real soon.
I went with the hooker super comp 1 3/4 long tubes, a full 3 inch setup with X pipe, and flowmaster 1 chamber delta flows.
this clip is open header with theese little turn downs i got. i will get a clip of the exhaust when i get back on thursday...
CLICK HERE
the car is leaking trans fluid, yes i know...
the clip of the car at the track was with 1 5/8 shorties, dual 2 1/4 pipes into 1 flowmaster 80 series.. EEK
8.0 @ 90mph with killed tranny.
it ran 7.8's the rest of the night.
I had a 383 built
508 hp
11 to 1 compression
CLICK HERE
8.0 @ 90mph with killed tranny.it ran 7.8's the rest of the night.
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
Sounds pretty nice, with 2.5" pipes and hooker or borla muffs , it would be sweet for the street
Car: 1986 Camaro
Car: 89 RS
Transmission: th350
You should be fine with duel 2.5s into what ever muffs you like. What are you cam specs the car sounds really nice lol
Engine: 3.0L/183
Originally posted by steveiguess
it is for the street
I know, i was comparing the borla's to the the open headers
Car: '82 Z28
Car: 1989 Iroc Z L98
Originally posted by EvilCartman
Uh no. Gotta let that thing breath and dual 2.5 will not cut it. It's been proven on a couple friends' cars when switching from dual 2.5 to dual 3, they ran better at the track. Even my car, some people may say single 3 inch was just fine but, what a huge difference going to dual 3 inch.
Many thanks for all your input! I'm interested as I currently have a dual 2.5inch set-up but will be increasing my power output significantly in the next year or two.
Car: '82 Z28
No dyno numbers other than the butt dyno telling him that it was quicker around the street. At the track, he went from 12.70's to 12.30's (your mileage may vary) The other friend's car had too many changes between runs but the car did run the same numbers with and without the exhaust, on the same day. As a guess on what hp level for the switch, 430 - 450.
. Thread
Hotrodboba400
Dec 10, 2019 07:07 PM
Chevykid810
Sep 28, 2015 12:57 PM
86White_T/A305
Sep 21, 2015 05:28 PM
