Question about Ypipe
I have a set of Hooker 2460 headers I got from Jet Hot several years ago and never got around to using.
(see HOK-2460-1HKR at summit)
I don't, however, have a ypipe.
Is there something out there that would work with these?
If not, are there any kits or make your own?
If not, is my only option a custom one?
Car: 89RS,89TBI FB, 91Z28, 89TPI FORMULA
Engine: 357 SBC TPI
Transmission: World Class T-5 (for now)
Axle/Gears: Strange 12-bolt 3.73
I have a leftover y-pipe from my Edelbrock header install. i run dual cats so i din't need it. I believe it's a 3" outlet and 2 2 1/2" inlets. I may consider selling if you're in a bind.
I'm in Richmond BTW.
Car: 1999 Saturn SL2
Engine: 4 cylinder
Transmission: 4-speed automatic
I believe Hooker actually sells a y-pipe seperately from these headers now. That would probably be the fastest and easiest way to get them working, but not necessarily the cheapest.
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
Here is a Custome Y-Pipe that I had made locally. It will connect to Hooker 2460 Headers I just sold. It is 2 1/2 inlet and 3" outlet that connect to a Hooker Catback system. The Y-Collector is a Flowmaster 2 1/2 in. & 3" out.
Let me know if you are interested....$75.00
16767HKR
"Y–Pipe–mid length, for part numbers: 2460HKR, 2460–1HKR and 2460–2HKR only, 82–92 Camaro: 265–400, aluminized steel"
http://www.holley.com/products.asp?product=16767HKR
http://store.summitracing.com/defaul...=egnsearch.asp
Why in the world would it go from 3" to 2.5"? Isn't that counterproductive?
The collectors on the 2460 are 3"
They have 3" to 2 1/2 reducer on each flange.
Ok, sounds good, price is good, I'm going to consider it. What would shipping be, ~$20?
Does anyone know if this summit part is bent to fit firebirds? It says "no" for universal application.
Do you have any pictures better than that?
https://www.thirdgen.org/techbb2/sho...hreadid=336185
Is the summit part meant for firebirds??? Anyone??
Engine: 357 SBC TPI
At the bottom of the page, you'll see "check to make sure this part fits your application". Plug in your car's specs and ye shall see.
