exhaust spitting out fuel??
Old Jan 11, 2006 | 09:03 PM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
well when i let my vehicle idle, you can literally see the gas spitting out of the exhaust, i would think this is a pretty bad idea, would this mean the vehicle is running too much and should set the carburetor? i was told turn the carburetor screws on the front to the right until the motor starts to "stumble" and it shold be set to stock, i know someone played with the settings to it should be set.
do you think is my problem for the fuel spitting out of the exhaust, motor running too much?
Old Jan 11, 2006 | 10:28 PM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
Are you sure that it's gas? Could it be just some water from condensation? Once the engine warms up the water would go away, gas I would think would catch fire.
Old Jan 12, 2006 | 08:54 AM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
oh maybe it is condensation, but why so much
Old Jan 12, 2006 | 09:36 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
A few winters ago, because of all the short in-town trips, condension in my Jeep built up and froze, not allowing the vehicle to start. The ice plug was the size of the tail pipe.
JamesC
Old Jan 12, 2006 | 12:47 PM
Jtufts's Avatar
Car: 1989 camaro rs
Engine: 305 TBI
Transmission: 700r
you can always smell it, gas has a totaly different smell , if smell dont work get a crappy rag sock it in whats comming out hit it with a match (best do it with a stick or something) i am sure if it goes up in flames fast its fuel but i am almost certin you can smell it and tell
Old Jan 12, 2006 | 05:02 PM
85z28guy's Avatar
Car: 85' Z28
Engine: 383 roller
Axle/Gears: Ford 9" 3.70
rough its just condensation. Your gonna have to wait for the good weather, take her for a boot, and work out the bugs. You'll find that all that time you spent adjusting things goes down the drain once it gets broken in a bit
Old Jan 12, 2006 | 05:24 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
thanks alot
Old Jan 12, 2006 | 05:34 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
yeah that definetly sounds like condensation. Just let your car warm up and it'll go away.
Old Jan 15, 2006 | 06:35 PM
2-toneTA's Avatar
Car: currently a 99 sable, and an infamous 98 4.3L 5sp S10
Engine: 220+4.3L, and a 200hp 3.0L
Transmission: 5sp nv3500, and an axn4 AT
My friend and I thought his TA was doing the same thing, except it did turn out to be condensation.....while the car was outside while we built the motor, some vandal thought it would be funny to put water in his exhaust, thankfully the kid didn't fill the muffler full and we were just freaking out about it thinking it was gas. Anyways, it sure looks like gas, but it isn't, in most cases.....lol.
Andrew
1992 Trans Am
May 10, 2023 07:19 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
bamaboy0323
Sep 3, 2015 06:07 AM
Dialed_In
Aug 20, 2015 01:45 PM
