loudmolth shotgun?
Subscribe
Feb 2, 2006 | 03:00 AM
i have a 305 firebird and i want a cheap exhaust that is loud but sounds good i was thinking of just buying the loudmoulth shotgun resonator and putting it after the cat then spliting it into two pipes from the resonator back out the car what you guys think. my first choice was bullet but there more high pitched.its about 120 for the install including the piping so around 200$ at max any suggustions
Reply 0
Feb 2, 2006 | 05:39 AM
exhaust is always a factor with these cars. you want to stick with something that sounds good and will be worth it in the long run.
I my self cut the y pipe so the exhaust points down then get two 90 bends and point them straight back or to the side then buy you some straight pipes and bolt them or weld them to the bends.. the cheap way but it works. or if you want fairly decent sound. stick with the y pipe and cut off the cat and straight pipe it all the way back split into a 1 inlet muffler 2 outlet such as flowmaster or somthing cheap off of ebay $40 easy stuff all the exhaust alone should be about $70 and do it yourself...
good luck i hope i have helped you in prices.. my way is cheap but i have mine bent out in a 90 degree bend the straight out to another 90 degree bend then going straight down the door. no camera so no pics sorry...
Reply 0
Subscribe
