What plug wires with Hooker Comps??
Old Feb 3, 2006 | 11:05 PM
Fast90Formula's Avatar
Car: 1965 Mustang
Engine: 347 stroker
Transmission: doing t-5 swap
Those of you running Hooker Comps what plug wires are you using? I noticed that the 3rd plug back on the 90 Firebird takes a straight boot wire....well they will no longer work they must me 90 degree boots.....I ordered in some Mallory wires just to find OEM style..... Please help!
P.S. Heads have straight in plugs not angled....
Old Feb 3, 2006 | 11:54 PM
tpi-hearse's Avatar
Car: 1989 Iroc, 1987and 1989 formula 350
Engine: 305tpi,350tpi,ls1
Transmission: 700r4,t-56
Axle/Gears: 3:08,3:27,3:23
I used taylor race wires on my old bird that had the hooker on it...best wires I ever used....
Old Feb 3, 2006 | 11:56 PM
Car: 1965 Mustang
Engine: 347 stroker
all 90's on the boots?
I'd really prefer to stick with....
Mallory
MSD
Accel
mainly because I can get them through work at a decent price and get em quick....
Old Feb 4, 2006 | 01:14 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
I have accel wires with 90 deg boots and standard A/C plugs. Little tight around the primaries but they clear ok. Also make sure to get a set of crimpers and dies if needed. Makes it MUCH easier and faster to set up the wires. Ive done it with pliers and screw drivers but it takes awhile to get them crimped that way. With a set of MSD crimpers, I get better then factory crimps in under a few seconds.
Old Feb 13, 2006 | 07:13 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
run them under the headers for the clean out of the way look
Old Feb 13, 2006 | 09:19 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Any good set of 8mm wires with 90 deg boots will work. The problem with Heades is the closeness of the pipes to the boots (not the wires) that burn though and result in problems. I solved this by using the LT1 metal 90 deg shields on the boots. Available at the dealer for about $1.50 each.
Old Feb 13, 2006 | 06:20 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
I'm partial to Moroso wires. I use them with the Moroso sleeve kit and run them under the headers. Get the cut to fit kit and run them nice and tight to the heads.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
Infested
May 22, 2018 11:56 PM
djmarch
Aug 19, 2015 12:07 PM
