Exhaust trick
Old Feb 12, 2006 | 06:57 PM
xunedeinx's Avatar
Car: 1991 firebird
Engine: V8 305
Exhaust trick
Im making my own exhaust, im taking the facotry y-pipe, cutting it where it joins, and making it a true duel, should be a lot better then stock.
But, to make it legal, i need a cat.
If i use the cat as the H-pipe, would it be legal because it is on the exhaust?
I know it wont do anything, barely even equalize pressure, but would it pass visual because its on there>?
Old Feb 12, 2006 | 07:08 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Actually, if its dual exhaust you are after, you'll need two cats... one on each pipe. Might be a good idea to check out the factory dual-cat setup.
Cat won't do **** if you use it as an H-pipe... and its gotta be in the factory location anyway. Since you need two cats, thats why I suggest you look at the factory dual cat setup.
Old Feb 18, 2006 | 10:48 AM
STEVE-83Z's Avatar
Car: 83 Z28 Camaro
Engine: 355 Holley Projection
Transmission: TH400
Axle/Gears: 10 bolt Zexal 3.73
Someone sells a dual in dual out cat. Not sure where I saw it ?
Old Feb 18, 2006 | 11:06 AM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
In alot of places true duals aren't legal because of the cat position change. Check your local smog laws.
Old Feb 18, 2006 | 12:44 PM
STEVE-83Z's Avatar
Car: 83 Z28 Camaro
Transmission: TH400
Think I saw them in JC Whitney catalog.
Old Feb 18, 2006 | 02:17 PM
xunedeinx's Avatar
Car: 1991 firebird
Engine: V8 305
i think its legal in NY long as you can pass visual w/ the cat.
69GTOby
Apr 18, 2016 02:34 PM
ssgt usaf
Sep 21, 2015 12:45 PM
87hellbird
Sep 14, 2015 05:08 PM
buckshot63
Sep 10, 2015 09:15 AM
hdis2002
Sep 8, 2015 02:52 PM
