If I got this electric cutout (pics) then how would I run the wires to the interior?
Old Feb 18, 2006 | 12:53 PM
ZZ4 86 Z28's Avatar
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
I found this electric cutout and I was all psyched to get it and put it in, and i realized something. How would I get the wires to the interior to hook up the switch? Also, where have you guys mounted your switches for these? And also, if i put it in front of the cat, will I be able to move the cat back? Or is there some kind of sensor that goes into it that will not be able to reach it anymore if I move it back? Thanks so much.
Old Feb 18, 2006 | 01:01 PM
jimp2001's Avatar
Car: Red on Red 89 RS
Engine: LO3 305 TBI
Transmission: TH-700R4
Axle/Gears: 10-bolt / 2.73
theres a grommet to run your shift cable in, drill a hole right next to it and pop a plastic grommet thru it.
I turned my ashtray into a switch panel for my fans, line lock, and cutout.
Old Feb 18, 2006 | 01:22 PM
ZZ4 86 Z28's Avatar
Thats what i was thinking. I was thinking of going with 3 switches. i wanted to do cutouts, line locks, and I needed a tc lockup cause i used to want to switch to a carb. I would love to see some pics, it sounds cool.
Anyways, what do you think is more fun? Ive got the stock cat on there now. I can either take the cat off and run it like that all the time, or get this cutout for $150. Cops are strict around here, I don't want to come home late or leave for school early too loud...
Old Feb 18, 2006 | 04:52 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
There is actually a place already in to floor board you can run the wires through. It's located just underneath the rear passenger seat...there is a rubber grommet that will have to be removed. OR, you could drill a hole. I to turned my ashtray to my switch panel...even added a few more LED's.
BRoss99
Aug 10, 2025 05:08 PM
Jorlain
Aug 24, 2022 05:11 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Exxon Limited
Aug 9, 2015 08:13 PM
