Header Gasket
Old Feb 25, 2006 | 08:43 AM
90CamaroTBI's Avatar
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
Header Gasket
I am thinking about to put headers onto my 305. Exhaust leaks are my biggest fears when it comes to exhaust.
I have been told that if you just run into a parts store and buy headers gaskets that they will just blow out and leak. So my question to you guys is, would I just want to go with felpro gaskets OR would I want the expensive copper ones?
Old Feb 25, 2006 | 09:22 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
I switched to Percy's dead soft gaskets a few years back. A little expensive at about $35 but worth it IMHO. Copper should be fine too.
Don't use the paper style, when they leak and you have to replace them, it's a PITA to scrape the remnants off the heads.
Old Feb 25, 2006 | 11:19 AM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
I use SCE copper gaskets on every motor that goes out and no problems in 4 years.
Old Feb 25, 2006 | 06:08 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
I dont care for the coppers they tend to break apart if a few bolts come loose. Ive use the dead soft aluminum gaskets with very good results for years. Perecy or Flowtech gaskets either one will work since they are the same.
Old Feb 25, 2006 | 08:01 PM
llvll4l2c91350's Avatar
i used gaskets for stock manifolds from the parts store on my headers for over 2 years that they were installed in the car w/o a single leak.
z 28 jari
Sep 14, 2021 10:03 PM
Chad Speier
Sep 24, 2015 12:32 PM
bamaboy0323
Sep 12, 2015 07:14 PM
hdis2002
Sep 8, 2015 02:52 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
