Header & duals question
Old Mar 19, 2006 | 08:38 PM
4RCEPWRD's Avatar
Car: 82Z28
I believe ive got the hedman shorties, just a question though i want to run 3"
duals with an xpipe but before doing this do your headers determine the diameter of exhaust you can run? If not then good if so then what do i need to do to run that exhaust setup? newbie so any input would be greatly appreciated. thanks.
Old Mar 19, 2006 | 11:02 PM
jm90camaro's Avatar
Car: 1993 Chevrolet Camaro Z28
Engine: 5.7L
Transmission: 4L60
Axle/Gears: 3.23 Posi
With shorties, your looking at alot of time contemplating on how you are gonna have the pipes rigged to come from the shorties. Collectors come in various sizes and most shops can flang pipes to accept bigger exhaust.
Old Apr 3, 2006 | 10:21 PM
1982z28's Avatar
Car: 1999 Z-28
Transmission: m6
Axle/Gears: stock/3.42
You have the edelbrock shorty's I just removed the AIR tubes and welded them shut. It also has a carsound(?) high flow cat and 3" pipe over the rear to the flowmaster
Old Apr 3, 2006 | 10:59 PM
eXesiv|83ta's Avatar
Car: 1983 Pontiac Trans AM
Engine: 355 chevy
Transmission: 700R4 Built
Axle/Gears: Built 10 bolt 3.73 gears
Old Apr 4, 2006 | 12:27 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Shorties make running duals tucked just as easy, if not, easier than using long tubes.
People that have never made exhaust will say it can't be done, will sacrifice ground clearance or, it's too difficult to be worth it.
It isn't... if you can fab.
Start with checking out the dual exhaust sticky.. good stuff..
https://www.thirdgen.org/forums/exha...l-exhaust.html
Old Apr 4, 2006 | 01:34 PM
4RCEPWRD's Avatar
Car: 82Z28
Hey thanks 82Z, I was wondering what they were I had forgot what you said
when I came up there, but anyways thanks for clearing that up and telling me it was 3", I think thatll work for me and Ill save myself the trouble and money and stick with what ive got, by the way the car is freakin awsome
everything you said it was and more
Frozer!!!
Jan 19, 2024 04:55 PM
beastin91rs
Oct 9, 2015 07:38 AM
tricky1
Aug 23, 2015 01:17 PM
Dialed_In
Aug 20, 2015 01:45 PM
redmaroz
Aug 16, 2015 11:40 PM
