Block Huggers a viable option
Old Mar 20, 2006 | 05:08 PM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
Ceramic coated block hugger headers are extremely cheap, and come in 1 3/4 primaries. I'm going to replace my cheapo Hedman headers when I do my K member install and I'm wondering if the block huggers would even be worth considering. I'm planning a Y pipe to a 3in single that dumps before the axle, or possibly true 2.5 duals (just a thought at the moment). Thanks again everyone.
Old Mar 21, 2006 | 12:55 PM
Correction these were FLOWTECH headers I'm replacing.
Old Mar 21, 2006 | 01:45 PM
MaNiAk86's Avatar
Car: 1983 trans am
Engine: Vortec 350 w/ a comp cam
Transmission: B&Mth350 2800holeshot
Axle/Gears: 10bolt 3.23's
i am also curious about the benefits and negatives of block huggers. i was planning on using hedman longtubes, but if the block hugger benefits out weigh the negatives of long tubes(ground clearence) then i would definetly give them a try.
Old Mar 21, 2006 | 06:05 PM
I'm looking at them as a substitute for shorties such as the Hooker 2460's, the hookers are over 300 shipped for the ceramic coated ones, 160 shipped for a set of non coated ones, and the block huggers are 140 shipped for a set of ceramic coated units. The hooker 2460's dont appear to be equal length, and of course the block huggers aren't and the hookers don't appear to be alot longer than the huggers. I realize therre's going to be a power sacrifice but does anyone know how much? I also think that even the block huggers will outdo my flowtechs, plus I will be able to use my billet plug wire looms which'll make me smile. Hopefully someone has experience with these because I'm real curious if this is a decent idea.
Old Mar 21, 2006 | 06:54 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You'd have the same ground clearance whether you used hedmans LTs or block huggers. The problem isn't with the headers, it's with routing the pipes around the frame rails.
Block huggers aren't an option at all with a stock K member anyway. They might clear a tubular K member, I don't know. They're also made for fitting into narrow-bodied applications like street rods, not for performance.
seiplentz
Aug 19, 2019 06:02 PM
customblackbird
Oct 1, 2015 04:30 PM
Trevor Tarry
Sep 15, 2015 02:04 AM
RyanJB
Sep 14, 2015 03:39 PM
64Chief
Sep 12, 2015 08:05 AM
