SLP HEADERS on a 305
Old Apr 8, 2006 | 09:29 PM
fbird92's Avatar
Car: '92 firebird
Engine: 305 HO
Transmission: 700R4 TCI performance
Axle/Gears: 10 bolt disc brake 3:42 slp auburn
I know SLP recomends running a 1"5/8 on the 305 and 1"3/4 on the 350. What if you put the 1"3/4 on 305? How much of a difference would it be, and would it be better than running stock exhaust manifolds. I know its an awefull lot of exhaust flow for a 305 and may decrease the low end torque. What are your guys thought about it. Let me know.
THANKS
Old Apr 8, 2006 | 09:54 PM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
it beats the hell out of a log style exhaust manifold.
Just my 2 cents
Old Apr 8, 2006 | 10:12 PM
gp423's Avatar
Car: 1989 Firebird Formula
Engine: LB9 305 tpi
Axle/Gears: open 2.73's baby!!
im not sure if 1 3/4" is too big for the exhaust port or not, if it is then i dont think it would be good to step up that large, im pretty sure if the tubes are too big, the gas coming out of the exhaust port has room to expand and looses velocity, which is not good, this causes a decrease in power(if this is wrong please forgive me, im still trying to learn everything). so if they are too big stick with the 1 5/8"
Old Apr 9, 2006 | 09:48 AM
fbird92's Avatar
Car: '92 firebird
Engine: 305 HO
I figured they may be to big. But I was able to pick them up for real cheap, but i also plan on running a 350 in the near future. Are they still going tao be better than stock if i put them on now and not wait to put the 350 in? Is it going to be ok since the Y pipe outlet is 2.5", I have heard that if you want to make a 305 better is to just put headers on with a 2.5" outlet to cat from the Y pipe and than go to a 3" cat back.
Old Apr 9, 2006 | 11:27 AM
skidude's Avatar
Car: 1987 Pontiac Trans Am GTA
Engine: 5.7 TPI, L98
Axle/Gears: 3.42:1
headers
If you already have them, use 'em. They'll be fine. They are not optimal for your 305, but if you are planning a 350 upgrade in the future, there is no need buying header just for the 305 when the 1-3/4" 's will work until then.
Regardless, they will be much better than you stock manifolds. You exhaust tone will be better too. If you are sure you will do the 350 swap, go ahead and run the exhaust as if you had the 350. There's no need in spending money twice.
Good luck.
Old Apr 9, 2006 | 11:41 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
most TPI 350s dont need 1 3/4 primaries either. I think John Lingenfelter uses stock corvette manifolds or 1 5/8 headers on engines up to 400hp
Old Apr 11, 2006 | 10:29 AM
91RS5speed's Avatar
Car: 91 RS
Axle/Gears: Auburn Pro / 3.42
It will be fine and you will gain power all threw the power band.
beastin91rs
Oct 9, 2015 07:38 AM
Wvcamaro
Sep 4, 2015 08:38 PM
Thirdgen89GTA
Aug 20, 2015 12:11 PM
camaro_rs350
Northern California
Aug 18, 2015 12:38 AM
