Heres a good question (or really stupid)
Old Apr 13, 2006 | 06:54 PM
sully91rs's Avatar
Car: 91 RS, 95 Z28
Engine: 305 tbi, 350 lt1
Transmission: 4l60, 4l60e
Axle/Gears: monsterous 2.73s in both
Heres a good question (or really stupid) about welding the exhuast system
I was quoted 400 to have headers, cat, and catback installed. I'd like to save some bucks by doin most the install myself and jus havin the shop weld it.
I'm mechanically inclined, but exhaust work is new to me. I don't weld. No tools, no where to do it. I want to pay someone to weld in my exhaust. BUT, can I install the header and fit the cat to it, and catback to to the cat, and have them hanging by the hangers so I can drive it 2 mins to a shop to get it all welded together?
Be nice if this question is nonsense.
Old Apr 15, 2006 | 01:18 PM
beachbumzT/A's Avatar
Car: '84 Trans Am
I would think that you could install the headers, y pipe, and cat yourself, those are easy enough. I am not too sure about the catback, that may require a lift or lots of time. 400 bux sounds very steep to me. I paid $100 plus 2 cases of Budweiser to have the exhaust shop in town here install my y-pipe and 4" Mufflex. Of course you are in Philly and I am in MS!!!
Old Apr 15, 2006 | 09:38 PM
Crusin' 1980's's Avatar
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
one problem might be removing your cat from your car...if you get your stock y-pipe off, the cat might not detach, but you could just cut it off...the headers and y-pipe are not that hard to do, but the cat-back you'd probably need a shop to do because the rear end needs to be up really high to get the I-Pipe over the axel...so if you could do the headers and y-pipe, pluls the cat, then you could just "rig" it up so that you can drive it to the shop and have them throw on the cat-back
Old Apr 16, 2006 | 08:14 PM
sully91rs's Avatar
Car: 91 RS, 95 Z28
I'm looking to use the Hooker catback (HOK-16823HKR), and in the image on summit the i-pipe is in two pieces. I'll try clamping it together while its up in the car.
Old Apr 16, 2006 | 09:26 PM
Car: 1988 SC Camaro
Engine: 305 TBI
If the I-Pipe is in (2) pieces then you can probably do it yourself with ease...when its a single pipe, then its tough to do unless the car is on a lift
ezobens
Aug 19, 2015 10:29 PM
Fronzizzle
Aug 19, 2015 01:36 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
