X-Pipe clearance Question
Old Apr 16, 2006 | 07:26 PM
Untamed Z's Avatar
I'm running Hooker LT's, no cats, 3" duals dumping before the rear axle. Just wondering if a 3" X-pipe kit is viable. I'm concerned with clearance issues. Wanted to know if any of you guys are running this way and how clearance is.
TIA
Old Apr 16, 2006 | 07:28 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If you're putting mufflers before the axle, there probably isn't enough room for an X pipe. It would have to go pretty much under the transmission, and that wouldn't leave you with a lot of ground clearance.
Old Apr 16, 2006 | 09:50 PM
Untamed Z's Avatar
So.........what I'm hearing is that if I have the x pipe just behing the tail of the tranny, I won't have room for 16" long mufflers before the rear axle? The driveshaft is 41", so it would seem like there would be room. Maybe I'm not quite understanding how much space (length) a universal x pipe kit would require. Any help appreciated.
Frozer!!!
Jan 19, 2024 04:55 PM
gixxer92
Sep 1, 2015 04:32 PM
downsouthboy
Aug 29, 2015 11:29 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
