Cat question
Old Apr 26, 2006 | 11:48 AM
Pocket's Avatar
Car: 91 Trans Am
Cat question
I have emissions equipment and am NOT looking to remove so
What works better with the computer and emissions
1) High flow cat with the air tube
2) Pipe with the air tube welded on
Stock 305 TBI with hooker LTs into a Y
Doin my research before I run into problems
Old Apr 26, 2006 | 12:47 PM
skidude's Avatar
Car: 1987 Pontiac Trans Am GTA
Engine: 5.7 TPI, L98
Axle/Gears: 3.42:1
HF cat or pipe
If your car doesn't have an aft O2 sensor, your ECM doesn't know if you have a cat or not. If you want to keep you car emission legal, go with a high flow cat with an A.I.R. tube.
If you don't want to spend the extra money on the high flow cat, and don't have to pass a visual emissions test, then strait pipe it. You can weld a fitting on the pipe anywhere you like for the A.I.R. tube to tie in. You may still pass the sniffer test, even without a cat.
chazman
Aug 28, 2018 03:25 PM
Out-Cast
Aug 22, 2015 07:49 PM
chazman
Aug 22, 2015 02:01 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
