What should i do?
Old May 3, 2006 | 10:42 PM
Screamin86's Avatar
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
What should i do?
ok im wanting to upgrade my exhaust. right now i have stock manifolds y-pipe no cat and 2.25 I pipe back to a flowmaster 80 series. it sounds ok but i want something a little better flowing and that will support future mods to this motor and the 355/383 im building this summer. i thought about going w/ hedman long tubes w/ 3in manderal y and some form of cat back since i plan on lowering the car and it will be driven a lot i dont wanna go through the hassel of true duals. i had even thought about going w/ just the headers y and a good cat and just run the pipes to the rear and split to two tails. i dunno how that would sound or flow though. so does anyone have any good ideas?
Old May 7, 2006 | 04:12 PM
Screamin86's Avatar
come on anyone got any suggestions? ive looked at some cat backs but im not sure what flows the best and has a good muscular sound but not too loud
Old May 10, 2006 | 11:15 PM
Screamin86's Avatar
no one has anything to suggest? i find that hard o belive. well im thinkg of goin w/ the hedmans no cat 3in back into loudmouth and split out the rear? ive heard some clips and talked to some ppl and i think that would be good for what i want mabey a lil loud but i will live w/ it. what does anyone think?
Old May 10, 2006 | 11:26 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
I'd suggest long tubes, non-catted Y-pipe back to a 3" muffler of your choice. Can't go wrong
Old May 10, 2006 | 11:44 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
Axle/Gears: stock 10 bolt-3.73 eaten posi
you can also go with the hooker shorty and y-pipe
its profromance that is cheap.
as for a cat back, its your chooce in sound like hunter said but make sure it is a 3'' setup.
Old May 11, 2006 | 10:26 PM
Screamin86's Avatar
ive looked into the shortys like you stated and a few others but was debating on if a shorty will be good enough for when i drop in my other motor!? the 3in should be depending on what muffler i use but im worried about the headers and y cause arent they only 2 1/2 collectors a/ 2 1/2 y? what would sound better shortys or long tubes or does it realy matter?
Old May 12, 2006 | 12:51 AM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
if your lowering your car i would stay away from LT's go wit the hooker 2055's
Old May 12, 2006 | 04:05 PM
Screamin86's Avatar
well from what ive read is that the hedman longtubes dont hang loers or much lower than the trany pan!? is that correct?
Old May 12, 2006 | 05:07 PM
s10irocspikes's Avatar
Car: 86 IROC
Engine: 350 Miniram
Edelbrock 1 5/8" shorty headders with 2 1/2" into 3" y-pipe. The flanges bolt directly into your 3" cat which you should keep but hollow out so you "look" legal. I would also recommend Flowmaster 3" catback exhaust with single 3" in/out muffler. Sure you only get one big exhaust pipe out the one side, but it flows better then the crossflow duel exhaust pipe muffler. The whole setup bolts together easily and can support 400+ HP with the best ground clearance especially if you're gonna lower it a bit.
