Any Negatives to Hooker 2055 over factory system??
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
The shop I'm starting to use for fine tuning my 88 IROC L98 has suggested I really be absolutely sure before I add headers to my car.
The shop was highly recommended and They build a lot of high end 1/4 mile vehicles and race. I'm very comfortable with their knowledge base.
Is there any negatives anyone can think of for adding a set of Hooker 2055's to my engine, expecially if I use high quality hardware?
It's been a long time since I added headers to anything other than a Honda or a Toyota. Using good hardware I've never had a problem with leaks. I have read many threads where people here have accidently ruined a lot of spark plug wires, but nothing other than that. Thanks, Nitro
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
The only thing I'm aware of is that the collector opening sometimes is not as big as it should be. It's supposed to be 2 1/2" but have seen them much smaller like around the 2" mark. It is an easy fix but just be aware of it as it will cost you some horsepower if the opening is not the right size.
Car: 1999 Saturn SL2
Engine: 4 cylinder
Transmission: 4-speed automatic
The only two things that I can think of is the aforementioned ball flange that is a tad narrow (easily fixed) and I personally think the y-pipe sits a little low, at least on my car. I never used to scrape on some certain uphill driveways but now I have to be extremely careful around any sharp uphill roads or bumps.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
but overall its not that bad, and my front end is low.
Car: 2004 Pontiac GTO
Axle/Gears: IRS 3.46
How is Hookers Y-pipe clearance with the Eibach Sportline springs? (net. 2" drop) My stock exhaust seems pretty low and i couldnt imagine if i drop it.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
JamesC
92projectcamaro
Jan 18, 2016 08:00 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
