sidepipes on a thirdgen?
Old Jul 2, 2007 | 02:22 PM
  #101
draco's Avatar
Car: 1992 Camaro RS 25th Anni.
Engine: 5.0l TBI
Transmission: 700R4 Automatic
Axle/Gears: 3.73 Gov lock
Re: sidepipes on a thirdgen?
Originally Posted by 1991CamaroRslow
Sidepipes, Louvers, and Cragars.... does it get any better than that?
Haha yea it does, TTops and Molly Hatchet.Unfortunately the louvres came off about a month ago.
Old Jul 2, 2007 | 06:33 PM
  #102
Josh R's Avatar
Car: Iroc
Engine: 350 4-bolt
Transmission: T5 non-W/C
Axle/Gears: 3.27 Open
I have an 86 iroc and someone may have asked this, but im too lazy to read everything haha. Is it possible to get the exhausts tight under the car. I was looking and i think it would work if it weren't for that damn flap of metal sticking down along the edge. Can you cut off a section of that. Like before where you put the jack. I love sidepipes but i don't want to see the whole pipe, just the exit. I think 2" off both headers and some glasspacks would be small enough too tuck up there behind the stock body kit. What do you think?
Old Jul 2, 2007 | 06:37 PM
  #103
Josh R's Avatar
Car: Iroc
Engine: 350 4-bolt
nvm. I saw that gray Camaro with the cherry bombs sticking out and what is stoping you from pushing it up higher?
Old Jul 2, 2007 | 09:26 PM
  #104
HotRodLarry's Avatar
Car: '83 Z28
DBLTKE.... that looks bad ***. That's the only way I'd do side exhaust. Have it come out right in front of the rear tire.
Old Jul 3, 2007 | 04:03 AM
  #105
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
I agree. I've always wanted to see somebody try that on a Camaro. There isn't too much room after the door but it may be possible. Eventually I'll try that on my car. LT's, 3" piping, X pipe, GMMG chambered mufflers and exiting like the picture I posted is my idea of the perfect true dual exhaust set up.
Old Jan 22, 2013 | 04:07 PM
  #106
jmcmillanjr.'s Avatar
Car: 1991 T/A GTA, 1991 T/A
Engine: 350 and 305
I've always liked the viper side exhaust, if there is a way to do it on my thirdgen I'm going to try it.
Attached Thumbnails sidepipes on a thirdgen?-266078d1255483361-side-outlet-exhaust
Old Sep 21, 2013 | 12:49 PM
  #107
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Originally Posted by DBLTKE
Maybe A little something like these?
Old post and picture, but that looks phenomenal!
Old Sep 24, 2013 | 05:27 PM
  #108
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Those body-integrated style side exit pipes are VERY hard to do... Yes that's muffler where floorpan used to be.
There's not really any better way to do it. There's floorpan and rocker panel structure where those pipes are trying to be.
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
fastrs1891
South Central Region
Oct 20, 2015 09:24 AM
Exxon Limited
Aug 9, 2015 08:13 PM
