Header question
Old Jun 16, 2006 | 03:02 PM
Rally Smith's Avatar
Car: 91 RS
Engine: 305 TBI
Axle/Gears: Factory 2.73 (unfortunately)
Header question
Is anyone else running edelbrock TES headers on their ride? I am looking to hear from someone that has the AIR tubes on top of the primaries that do not have the AIR system hooked up. I want to know if you have any chirping or squeeking noises from them. Please let me know if you have any problems or none at all.
Thanks,
R.S.
Old Jun 16, 2006 | 03:18 PM
90CamaroTBI's Avatar
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
I would figure that if you capped them off and they didnt leak, then you wouldnt have any problems with noises.
Old Jun 16, 2006 | 03:24 PM
Car: 91 RS
Engine: 305 TBI
I have capped them off. It sounds like it's coming from the y pipe. Like there is a piece of metal that is hanging in the path of the exhaust. As it rushes by it makes this god awful noise around 1000 to 1800 RPM's. I just need to make sure that it is not the air tubes before I send them back to Jegs for my replacements.
Old Jun 16, 2006 | 03:59 PM
trumps2000's Avatar
Car: 1985 Z28
Transmission: T-5 5 Spd
Axle/Gears: Built 10bolt w/3.73s
I have the Edelbrock TES headers with AIR tubes and they don't whistl or anything. I also have removed the valve portion of the EFE.
Old Jun 16, 2006 | 04:03 PM
Car: 91 RS
Engine: 305 TBI
I don't mean to come across as a dumb a$$ but what is the EFE?
Old Jun 16, 2006 | 07:35 PM
Coach Hawk's Avatar
Car: 91' Pontiac Firebird
I've got 4th gen Edelbrocks on my car, AIR fitting are capped off and don't make a sound.
Old Jun 16, 2006 | 09:46 PM
trumps2000's Avatar
Car: 1985 Z28
I had to look at the book and remember what EFE stood for. Early Fuel Evaporative system is an emission system, a vacuum-controlled valve just after the exhaust manifold. My LG4 came with one on the drivers side. Someone correct me if I'm wrong, when the engine is cold started, its closed (because of a vacuum thermostat) and forces some of the exhaust through the heads and intake manifold to heat up the carb quicker.
My AIR tubes aren't capped off, they have new check valves just no tubes hooked up as of yet. I guess you could temporarily take off the Ypipe to see if it goes away?
Old Jun 19, 2006 | 08:49 AM
Car: 91 RS
Engine: 305 TBI
Thanks Coach Hawk, that's what I wanted to know.
I am going to take the y pipe off tonight and see if it goes away. That's going to be loud. SWEET!
Thanks for the replies guys.
R.S.
Last edited by Rally Smith; Jun 19, 2006 at 08:50 AM. Reason: Automerged Doublepost
Old Jun 19, 2006 | 11:47 AM
gray89vert's Avatar
Car: 1989 RS convertible
Engine: 305 TBI LO3
Transmission: TH-700-R4
Axle/Gears: stock axles 3.73 LSD
I got the edelbrock headers the AIR fittings were welded shut so obviously they wont make any noise. Your problem may even be a gasket intead of the y-pipe. Just my .2
Old Jun 19, 2006 | 01:20 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Correct up to the last 2 words. It's intended to heat up the floor of the intake manifold so fuel will not pool there but will "evaporate".
beastin91rs
Oct 9, 2015 07:38 AM
hectre13
Sep 8, 2015 03:38 PM
tricky1
Aug 23, 2015 01:17 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
