open headers with y pipe?
Old Jun 20, 2006 | 12:12 AM
ThrottleJunkie's Avatar
i was talking with my buddy today about open headers and what to do to make the exhaust street legal. he said you can get a y pipe that has a valve that opens when you want streetable exhaust and it closes when you want open headers or something like that so if someone starts revving their engine at you you can put em to shame lol. is this true?
Old Jun 20, 2006 | 11:18 AM
stroker_SS's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
he was more than likely talking about an exhaust cut out, you just unbolt the cap at the y and there ya go, open y. You can also get them electrically operated versions.
Old Jun 20, 2006 | 05:07 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Yeah, he's talking about a cutout.
The manual ones are on summit for like $30 bucks. QTP sells a good electric one, it's like $150+ though.
Old Jun 20, 2006 | 05:29 PM
do you think the electronic ones are worth the money?
Old Jun 20, 2006 | 06:37 PM
gray89vert's Avatar
Car: 1989 RS convertible
Engine: 305 TBI LO3
Transmission: TH-700-R4
Axle/Gears: stock axles 3.73 LSD
no, electric ones can be really crappy if you dont get a good one
Old Jun 20, 2006 | 09:09 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
The plus side is you don't have to crawl under the car to open them up. Just flip a switch. This is useful at stop lights.
Old Jun 20, 2006 | 09:20 PM
thats what i was thinking. can give someone quite a surpise when they think their car is faster than yours
Old Jun 20, 2006 | 09:51 PM
gray89vert's Avatar
Engine: 305 TBI LO3
just so you know, running open headers can makes your car faster and a lot louder but its actually really bad for your valves. No back pressure means your valves are going to get worn out faster.
Old Jun 20, 2006 | 11:25 PM
EvilCartman's Avatar
Car: '82 Z28
Originally Posted by gray89vert
...but its actually really bad for your valves. No back pressure means your valves are going to get worn out faster.
That's a load of crap.
Old Jun 20, 2006 | 11:28 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I've only heard an electric cutout on a car once, 86q_ta's car. 305 LG4. it sounds awesome, i'd highly recommend it.
They tend to leak, so even with it closed, it's more rumbly than stock.
and yea, that's crap. There is some correlation to running open headers and burnt valves, *I think*. But that's due to running lean.
Old Jun 21, 2006 | 09:52 AM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
I think it also had to do with valves getting bent/warped due to heating up and cooling too fast. Still though, that may have been true in the 60's but not with todays parts and it has absolutly nothing to do with back pressure.
Old Jun 21, 2006 | 01:51 PM
gray89vert's Avatar
Engine: 305 TBI LO3
in that case...i can run open headers on my car all the time with no damage to anything... well unless it melts something?!?!
Old Jun 21, 2006 | 02:54 PM
Sonix's Avatar
Car: 1982 Trans-Am
umm yea, but you'll go deaf first.
Old Jun 21, 2006 | 09:34 PM
gray89vert's Avatar
Engine: 305 TBI LO3
my car is loud with headers open, but only when your standing by the engine, like with the hood open revving it. I can deal with it from inside the car as long as the windows are closed. I just dont feel like modifying my y pipe right now. lol
Old Jun 22, 2006 | 09:53 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
Open headers wont hurt the valves, it will just kill your lowend torque. Idealy, you should have the cutout closed at take off, then open it as the rpms go up. Cut outs are fun, but the rasp and 5 hp lost isn't worth it. Just get a test pipe and 4 inch mufflex. that will be loud enough.
92projectcamaro
Jan 18, 2016 08:00 AM
hectre13
Sep 8, 2015 03:38 PM
formula_novice
Sep 5, 2015 03:58 AM
drathaar907
Aug 6, 2015 04:20 PM
