cat converter in the rear... bad idea?
Old Jul 23, 2006 | 02:55 PM
ttypecamaro's Avatar
Car: 09 Cobalt SS Sedan. 92 Z28 vert
Engine: 2.0T EFR6758; 5.0TT T3/T4 8psi
Transmission: F40; 700r4
Axle/Gears: 3.76 LSD; 3.23 posi
I have two 3" catalytic converters I want to put on my car. I'm building the exhaust myself since theres not much to buy for v8 turbo f-bodies. I'm not using any mufflers(the turbos keep it quiet enough), so I was wondering if I could put the cats behind the rear axle so I don't have to fit them under the passenger seat. That would save me a ton of work. The only problem is that they might not get hot enough to work properly and get clogged. I'm doing a 3" y-pipe into a single 4" pipe over the rear.
Does anyone think it would be fine to put the cats there
Old Jul 23, 2006 | 04:08 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Exactly, thats why the are placed as close to the engine as possible.
Old Jul 23, 2006 | 06:30 PM
Steve86TA's Avatar
Car: To many to list
I think you answerd your own question.They need the heat to work properly
Old Jul 23, 2006 | 08:51 PM
I thought so, but I was just wishing it would still be hot enough in the back.
Old Jul 23, 2006 | 10:30 PM
superGMman's Avatar
Car: '92 Toyota Pickup
Engine: 22R-E
Transmission: 5sp Manual
Axle/Gears: 4:??
I live in smog **** territory but it might be illegal in your area as well.
It might.
Old Jul 24, 2006 | 12:15 PM
It probably is illegal... its just that no one enforcing it could ever tell the difference! Baltimore is a copycat city of CA emmisions/inspection standards, but the "inspectors" are too ignorant to enforce it properly.
Old Jul 24, 2006 | 01:58 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
yep, like everyone said, they need to be as close to the engine as possible.
Old Jul 24, 2006 | 02:59 PM
camarodarrell's Avatar
The exhaust temp. on a turbo car is higher than on a naturally aspirated car so you might be able to get away with it. Get a temp gun and compare the temp. of the exhaust pipe in the rear of your car with the temp of the exhaust on your bro's car under the seat.
Old Jul 24, 2006 | 07:27 PM
thats a good idea. I'm going to do it the hard way to be sure. I fabricated the 3" pipes (from the downpipes to where the cats are supposed to go) today... so i'll just put the cats on the ends of those under the passenger seat, and then merge the cats together into a 4" pipe.
One of my brother's tailpipes melted the dyno strap when he was on the dyno, so its probably pretty hot back there...he doesn't have any cats.
Old Jul 26, 2006 | 10:56 PM
I finished the exhaust system and put the cats undr the passenger seat. It was a tight fit! now those converters turned out to be a huge restriction on my exhaust! I only see 5 psi of boost when before I had 8psi.
Old Jul 27, 2006 | 01:16 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
actually quite the opposite unless maybe you consider before the turbo inside the manifolds. but after that the turbo cools the exhaust down a little bit plus with the generally richer mixture that even further helps to cool the egt's down.
jaridjohn
Jul 8, 2024 03:49 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
nuggie
Aug 25, 2015 01:27 PM
Jlanz55
Aug 17, 2015 07:15 AM
gta power
Aug 13, 2015 06:15 AM
