can I cut 1" off the pipes on the 2210s
Old Aug 9, 2006 | 04:13 PM
BOTTLEDZ28's Avatar
Transmission: A4
Is it possible to cut about 1 inch or maybe more off the primary pipes on the hooker 2210s in order to gain a little more ground clearance? They is a spot on each pipe where it is straight up and down and it looks like a good spot to cut out some material and then weld it back up togheter. Will this work? I already have ES poly motor mounts which raises the engine a little anyway. I am also running Eiback pro kit springs. I donthave theheaders in front of me to test fit and I really dont want to buy them and find out if wont work.
Old Aug 9, 2006 | 06:07 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
never tried it, but if you can cut the headers, put them back togeather, and have them still fit you should be fine, maybe get a second opinion first
gta892000
Sep 16, 2015 12:37 AM
Fox118
Sep 12, 2015 09:29 PM
Camaro_383
Sep 11, 2015 11:28 PM
Nick McCardle
Sep 10, 2015 08:36 PM
