ticking wen accelerating
Old Aug 10, 2006 | 11:31 PM
86V8Z28Camaro's Avatar
Car: 86' Z28 Camaro
Engine: 350 holly 650cfm carb
Axle/Gears: 3:73 posi
wen i accelerate i have this weird tickin noise. wut could this be? please help thanks
Old Aug 11, 2006 | 01:00 AM
ZimGTA's Avatar
Car: 88 GTA
Engine: 383
Transmission: 700 r
Leaky exhaust manifold or a valvetrain problem?
Old Aug 11, 2006 | 02:39 PM
Chr1s46536's Avatar
Car: 91 RS
Engine: 305 TBI
I had a similar noise it was a cracked flexplate
Old Aug 11, 2006 | 05:12 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Likely manifold gaskets are leaking... replace them and see what happens. Usually you can see where they were leaking when you remove them old gaskets.
Old Aug 15, 2006 | 04:16 PM
SpeedMetalT/A's Avatar
Car: 87 Trans Am
Engine: L98 350 w/carb
Transmission: TH350
If you have the stock rochester carb it has metering rods that make a ticking noise during acceleration.You can also hear them when you turn the ignition on and the engine is not running.
Old Aug 20, 2006 | 11:21 AM
xgtharo86x's Avatar
Car: 86' Trans am
Engine: 85 LG4-non cc carb(building a 350)
Transmission: Rebuilt 700R4,vette servo,2200stall
Axle/Gears: 2.73 Posi
it could be your lifters but its most likely the exhaust manifolds
Old Aug 20, 2006 | 12:03 PM
kjvail1204's Avatar
Flex Plate
Dude i had this bad, and i later had to drop my trany, and low and behold it was the flex plate, mine was so bad that the bolt pattern stayed on the engine. I know its some work but id go with the flex plate first, its the hardest job but if it goes it can go through your trany, engine, or into your drving compartment, For safty alone its worth looking into , drop the trany, and TC and look for cracks
Old Aug 20, 2006 | 12:33 PM
bfox88's Avatar
Car: 90 IROC-Z
my old RS did that occassionally. it was a cracked exhaust manifold gasket
Old Aug 20, 2006 | 02:42 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Stock exhaust manifolds do not have gaskets. Headers do.
Old Sep 7, 2006 | 02:05 PM
kjvail1204's Avatar
Update?
Hey dud ejust trying ot get and update on what youfound out. We would like to know so that we as well as others know what to look for in the future
Old Sep 7, 2006 | 02:16 PM
Air_Adam's Avatar
Couldn't hurt to put some in there though, if they are indeed leaking. Whats $10 and a 1/2 hour of work to get rid of an irritating exhaust leak?
Pac J
May 17, 2020 10:44 AM
RedLeader289
May 28, 2019 01:47 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
david068513
South East Region
Sep 13, 2015 11:24 AM
